ROTEL RB 1070
ΠΩΛΕΙΤΑΙ ΣΕ ΑΡΙΣΤΗ ΚΑΤΑΣΤΑΣΗ ΠΡΩΤΟ ΧΕΡΙ ΤΕΛΙΚΟΣ HI-END 2X130 Rotel RB-1070 Stereo Power Amplifier 450 EURO ΤΗΛ 6907393139
RB-1070
The newest interpretation of a classic Rotel award-winning power amplifier design, the RB-1070 continues the tradition of oversized toroidal transformer and high capacity power supply. In addition, Symmetrical Signal Trace circuit topology assures the precise interchannel timing clues necessary for pinpoint stereo reproduction. At 130 watts per channel (20 Hz to 20 kHz @ 0.03% THD into 8 ohms), the RB-1070 is more than capable of meeting the challenges of even the least efficient loudspeakers. An internal bridge option provides truly prodigious 330 watt output capability. Front panel LED status indicators show power, protection, and bridged mode for instant system analysis. And a separate input and output for 12 volt "trigger" signals increases flexibility by allowing the amplifier to be totally integrated into even the most complex remote-controlled systems.
Continuous Power Output2 x 130 watts
Power Configurations
Watts/Channel
2 x 130 watts
1 x 360 watts
all channels driven,
unbridged, 8 ohm load,
20 to 20k Hz, 0.06% THD
Total Harmonic Distortion
(20 Hz - 20 kHz)
cont. rated power
one-half rated power
one watt per channel
0.03%, maximum
0.03%, maximum
0.03%, maximum
Intermodulation Distortion
(at rated power, 60Hz:7kHz = 4:1 )
0.03%, maximum
Damping Factor (8 ohms)
Input Impedance/Sensitivity
500
1.0 V / 33 kOhms
Input Overload Level
Frequency Response
5V
4Hz - 100kHz +0.5 dB, -3 dB
Signal to Noise Ratio (IHF A)120 dB
Power Consumption:400 Watts
Power Requirements:115 volts, 60 Hz (U.S. version)
230 Volts, 50 Hz (European version)
Dimensions (W x H x D):430 x 121 x 350 mm
16 15/16" x 4 3/4" x 13 3/4"
Weight (net):11.9 kg, 26.25 lb
Alkimos
