Rotel RB-1582 MKII
sps
Rotel Τελικός 2 Χ 200 watt. Αγορά 2ος 2016. Με Απόδειξη Αγορας, πλήρη συσκευασία.
Σε Τέλεια Κατάσταση. 1.150 Ευρώ.
Δεν βαζω χαρακτηριστικά του το Διαδύκτιο είναι γεμάτο. εάν κάποιος θέλει φωτο η στοιχεία στήν διάθεση του.
6942980705 Σπύρος
sps
Διαθέσιμος ,
Ειναι από τους πολύ καλούς μεσαίας κατηγορίας , καλόηχος με πολύ ρεύμα
stampol
Οι θυσίες...
Πιστευω πως θα ηταν καλο 2 φωτο του ενισχυτη στο νημα σου οπως και αναφορα χρωματος αυτου.
  • Like
Reactions: sps
sps
Εχω βρει 360 Watt @ 4 ohm
Στο manual αναφέρει "διπλασιασμό" ?
Δεν ειχα δώσει προσοχή ποτε σε αυτό δεν εχω 4 ohm
Απο το Manual:
A Word About Watts
The RB-1552 power output is quoted as 130 watts for each channel, and the RB-1582 power output is quoted as 200 watts for each channel, when both channels are operating together at full power.
Rotel has chosen to specify the power output in this way because, in Rotel’s experience, it gives the truest value of the receiver or ampli er’s power capability.
When comparing speci cations for different products, you should be aware that power output is often speci ed in other ways, so you may not be comparing like with like.
For example, the power output may be quoted with only one channel operating, giving a higher maximum gure. The high performance power supplies of the Rotel ampli ers ensure that they will produce the full speci ed power output to one or both channels.
A loudspeaker’s impedance rating indicates the electrical resistance or load it offers when connected to the ampli er, usually 8 ohms or
4 ohms. The lower the impedance, the more power the speaker will need. In effect, a 4 ohm speaker will require twice as much power as an 8 ohm speaker.
So ideally, the ampli er should be give double the power into a 4 ohm load – a rating of 100 watts into an 8 ohm load should become 200 watts into 4 ohms. Using lower impedance speakers makes greater demands on the ampli er’s power supply, because it will be drawing more current and giving off more heat.
However, Rotel ampli ers are designed to work into any speaker impedance between 8 and 4 ohms, and with all the channels working up to their full power. Because the Rotel design is optimized for use with all channels operating together, Rotel is able to specify the true power output for both channels.
This can be important for your enjoyment, too. When watching movies, it’s nice to have the ampli er able to reproduce full power into all the channels at the same time, especially in the case of a volcano exploding!
sps
Ο Ενισχυτής δώθηκε εκτός Forum.
Ευχαριστώ Πολύ τους Διαχειριστές για την φιλοξενία.!!!
και όλους εσάς.
opanamas
