SAMSUNG 40IN HD ΔΕΚΑΕΤΙΑΣ
ΓΙΑ ΚΑΠΟΙΟΝ ΠΟΥ ΘΕΛΕΙ ΚΑΤΙ ΑΠΛΩΣ ΝΑ ΠΑΙΖΕΙ.
ΕΧΕΙ ΕΝΑ ΣΗΜΕΙΟ ΠΟΥ ΜΑΥΡΙΖΕΙ ΠΟΛΥ ΕΛΑΦΡΥΑ ΜΑΛΛΟΝ ΛΟΓΩ "ΜΠΑΛΙΑΣ".
ΜΕ ΤΟ Τ/Χ ΤΗΣ. ΘΕΛΕΙ ΑΠΟΚΩΔΙΚΟΠΟΙΗΤΗ.
50 ΕΥΡΩ.
ΠΑΡΑΛΑΒΗ ΑΠΟ ΡΕΝΤΗ.
Αν δεν κάνω λάθος πρέπει να είναι 32αρα....έτσι ; και η τότε τιμή (καμιά 12 - 14 χρόνια πίσω) στα 750 ευρώ.
40ΑΡΑ ΕΙΝΑΙ.
Product DescriptionSamsung LE40S86BD - 40" LCD TV
Product TypeLCD TV
Diagonal Size40" - widescreen
Dimensions (WxDxH)108 cm x 30 cm x 69 cm - with stand
Weight21.5 kg
ColourBlack
Digital Television CertificationHD ready
Resolution1366 x 768
Display Format720p
Input Video Formats480p, 720p, 1080i, 480i, 576i, 576p
Video InterfaceComponent, composite, HDMI, S-Video, SCART
HDMI Ports Qty2 port(s)
PC InterfaceVGA (HD-15)
HDCP CompatibleYes
TechnologyTFT active matrix
Progressive ScanYes
Image Aspect Ratio16:9
TV Tuner1x analogue, 1x digital
Multi-channel PreviewPicture-in-picture (PIP)
FeaturesClock, Auto Power Off, parental control, on-screen menu, DNIe (Digital Natural Image engine), game mode, SKY HD tested
Sound Output ModeStereo
Speaker System2 speakers
Sound EffectsSRS TruSurround XT
Stereo Reception SystemNICAM, A2
Remote ControlUniversal remote control - infrared
PowerAC 120/230 V ( 50/60 Hz )
GENERAL
Product Type40" LCD TV
HDCP CompatibleYes
DimensionsWith stand
Width108 cm
Depth30 cm
Height69 cm
Weight21.5 kg
Enclosure ColourBlack
DISPLAY
Display Format720p
Dynamic Contrast Ratio7000:1
Brightness500 cd/m2
Progressive ScanProgressive scanning (line doubling)
Widescreen ModesConventional 4:3, Auto Wide, Wide Zoom, Zoom, 16:9, Just
Viewing Angle178 degrees
Viewing Angle (Vertical)178 degrees
Pixel Response Time8 ms
Colour Temperature ControlYes (Warm1/Warm2/Normal/Cool1/Cool2)
Picture AdjustmentStandard/Dynamic/Film/Custom
TV TUNER
DIGITAL TV TUNER
Digital TV ServiceTNT
VIDEO FEATURES
HDTV ReadyBuilt-in
Supported Computer Resolutions1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 720 x 400, 1360 x 768
TeletextYes
Teletext Memory1000 pages
Freeze MemoYes
Parental Channel LockYes
Closed Caption CapabilityYes
REMOTE CONTROL
TypeUniversal remote control - infrared
Remote Control ModelSamsung TM86
Supported DevicesVCR, sattelite TV system, cable box, DVD player
AUDIO SYSTEM
Surround ModeBuilt-in
Audio ControlsSound mode, equalizer, balance
EqualiserYes (5-band)
Speakers Included2 speakers
Output Power / Total20 Watt
FeaturesAuto volume adjustment, balance control
Speaker(s)2 x right/left channel speaker - built-in - 10 Watt
opanamas
