Samsung DLP HDTV
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
50 ιντσων με HDMI , Trusurround XT, και αντιθεση 2000:1
Παρουσιαστηκε ηδη σε Ιαπωνια και Κορεα και ακολουθει η Ευρωπη( συντομα ελπιζουμε)
Μήπως εννοείς αυτή?
Samsung HL-P5085W
Samsung HLP5085W Details
The new 85-Series presents Samsung's fourth-generation optics and advancements in picture performance. A single, postage stamp-sized Digital Micro-Mirror Device (DMD) generates astoundingly realistic high-definition video images. This DLP television lets you experience movie theater quality video, with deeper blacks and more robust colors, all from the comfort of your own favorite chair.
DLP (Digital Light Processing) TV (1280H x 720V Pixels)
Samsung Cinema Smooth Gen 4 HD Fourth-Generation Optical Engine
Single Panel Digital Micro-Mirror Device (DMD) Design
No Possibility of Convergence Errors
High-Output, 0.80" DMD Technology by Texas Instruments
Smooth, Film-Like, Pixel-Free Images
2500:1 Contrast Ratio With Outstanding Color And Deep Black Levels
DVI-HDTV Input (Digital Visual Interface)
HDMI Input (High Definition Multimedia Interface)
2 Component Video Inputs (480i/480p/720p/1080i Compatible)
Samsung's Latest Generation DNIe Video Enhancer
Cinema Smooth Film-Mode 3:2 Pull Down Powered By Genesis
1280 x 720 Digital Format Converter For All Inputs
HDTV Performance With Add-On HDTV Tuner Or HD Receiver (Not Included)
No Screen Aging Or Burn-In Effects for Worry-Free Enjoyment
30-Watt Stereo Audio System With SRS TruSurround XT
PC DB 15 Video Input (1 Rear), S-Video Inputs (2 Rear), Composite Video Inputs/Output (2/1 Rear), RF In/Out (2/1 Rear), Audio Inputs/Output PC/DVI/Analog In/Out (1/1/4/1 Sets Rear)
Lamp Life: 5000 - 8000 Hours
3D Y/C Digital Comb Filter
2-Tuner PIP With Side-By-Side Split Screen
4 Wide Modes (Zoom, Wide, Panoramic, Normal)
Enhanced Low-Light Scene Detail Performance
Quiet Operation (48dB)
Universal Remote Control
V-Chip Parental Control
Unique Pedestal Light-Weight Design (Fits Where Others Won't)
Size (H x W x D): 54.7" x 53.6" x 20.5" Including Built-In Pedestal
Weight: 124.5 lbs. Including Built-In Pedestal
Δεν ξέρω τελικά αν είναι η ίδια ή κάποιο πιο εξελιγμένο μοντέλο αυτό που παρουσιάζει ο Ανδρέας, αλλά αυτήν που αναφέρω την έχει συγγενής μου στις Η.Π.Α.
intergrale
