Schiit Yggdrasil
m1ts0s
News poster
Yggdrasil is the ultimate expression of Schiit’s bitperfect approach, and
the antithesis of noise-shaping DACs and technologies such as DSD. With
proprietary technology from input stage to clock regeneration to digital
filter to D/A conversion and analog output stage, Yggdrasil (the world tree
in Norse legend, and the source of all things) resets the bar for DACs.
Inputs: USB, Toslink, Coax, BNC, AES/EBU
Outputs: balanced XLR and single-ended RCA
Clock Regeneration: proprietary Adapticlock topology with analysis of quality of incoming datastream, as well as VCO and VCXO reclocking
Phase Inversion: selectable via front panel button
Digital Filter: proprietary Schiit closed-form bitperfect digital filter based
on <REDACTED>
D/A Conversion: proprietary fully differential configuration based
on<REDACTED>
Analog Stage: proprietary Schiit Pivot-Point differential current-feedback topology, fully discrete, with ultra-low-noise JFET and bipolar devices
Power Supply: 4 choke-input, shunt-regulated supplies feeding 20+ stages of discrete and integrated local regulation
Size & Weight: 16 x 12 x 3.875”, 30 lbs
Estimated Price & Availability: $1700-1900, early 2014
ALL SPECS AND DATA SUBJECT TO CHANGE BEFORE RELEASE
m1ts0s
News poster
Forget everything you know about DACs. Yggdrasil is the world’s only closed-form multibit DAC, delivering 21 bits of resolution with no guessing anywhere in the digital or analog path. We’ve thrown out delta-sigma D/As, traditional digital filters, and sample rate conversion to preserve the original samples all the way through from input to output. To do this, we had to rethink everything about a modern DAC. Let’s take a closer look:
Closed-Form Digital Filter Preserves Original Samples
Most DACs simply use the stock digital filters embedded in their D/A converters. But even the most sophisticated ones, using their own digital filter algorithms, don’t have what Yggdrasil has—a digital filter with a true closed-form solution—meaning it retains all the original samples, as it performs a true interpolation. This digital filter gives you the best of both NOS (all original samples retained) and upsampling (easier filtering of out-of-band noise) designs—and it is only available on Yggdrasil.
21 Bits, No Guessing: Mission-Critical D/A Technology
When doctors are trying to diagnose whether you have gas or cancer from MRI results, or when the military is trying to ensure a missile hits an ammo dump and not a nunnery next door, they don’t use “24 bit” or “32 bit” delta-sigma D/A converters. Instead, they rely on precision, 20-bit ladder DACs, like the Analog Devices AD5791. This allows them the bit-perfect precision they need for critical applications, rather than the guesswork of a delta-sigma. We chose this same critical technology for Yggdrasil, in a balanced configuration that increases effective resolution to 21 bits. Following these unique D/A converters are sophisticated discrete JFET buffers and summers.
Adapticlock and USB Gen 3: Advanced Input Optimization
Yggdrasil accepts up to 5 digital inputs and carefully manages them with our Adapticlock™ clock regeneration system. Adapticlock is the most sophisticated clock management system in the world. It assesses the quality of all inputs, measures their incoming center frequency and jitter, and automatically routes the input to the best possible clock regeneration system. Yggdrasil also features our all-new USB Gen 3 input module, for even better performance than the acclaimed Gen 2 USB input.
Made in USA
By “made in USA,” we mean made in USA. The vast majority of the total production cost of Yggdrasil—chassis, boards, transformers, assembly, etc—goes to US companies manufacturing in the US. Our board house is 20 minutes away from our office in Newhall. Our chassis guys are just over the hill in the Valley.
5-Year Warranty
Yggdrasil is covered by a limited warranty that covers parts and labor for five years. That’s 5 years. Yes. FIVE. Which is up to 5X that of our competition, if you weren’t so hot at math. Note the marketing weasel-wording “up to.”
15-Day Satisfaction Guarantee
Try Yggdrasil in your own house for 15 days. If you don’t like it, simply send it back for a refund, minus a 5% transaction fee. Try spending 15 days in an audio store. They’ll kick you out. Unless you buy them donuts. Maybe.
Specs
Inputs: AES/EBU XLR, RCA SPDIF, BNC SPDIF, Optical SPDIF, USB
Input Capability: up to 24/192 for all inputs
Input Receiver, SPDIF: AKM 4313
Input Receiver, USB: C-Media CM6632
Clock Management: Bitperfect clock management at all native sample rates via Adapticlock analysis and VCXO/VCO regeneration, plus asynchronous USB Gen 3 module
Digital Filter: proprietary Schiit bitperfect closed-form digital filter implemented on Analog Devices SHARC DSP processors
D/A Conversion IC: Analog Devices AD5791 x 4 (2 per channel, hardware balanced configuration)
Analog Stages: Fully discrete JFET buffers for balanced output and discrete JFET summing stages for single-ended output, direct coupled
Output: One pair XLR balanced and two pairs RCA single-ended
Output Impedance: 75 ohms
Frequency Response, Analog Stage: 20Hz-20Khz, +/-0.1dB, 0.5Hz-200KHz, -1dB
Maximum Output: 4.0V RMS (balanced), 2.0V RMS (single-ended)
THD: Less than 0.006%, 20Hz-20KHz, at full output
IMD: <0.007%, CCIR
SNR: > 117dB, referenced to 2V RMS
Power Supply: two transformers (one for digital supplies, one for analog supplies) plus one input choke for discrete, dual mono, shunt-regulated analog +/-24V supply, plus 12 separate local regulated supplies for DACs and digital sections, including high-precision, low-noise LM723 regulation in critical areas.
Upgradability: Fully modular architecture. Separate digital input board, USB input board, DSP engine board, and DAC/analog output boards.
Power Consumption: 35W
Size: 16 x 12” x 3.875”
Weight: 25 lbs
$2,299
http://schiit.com/products/yggdrasil
Πολύ ντόρος εχει γίνει πριν βγει ελπίζω να ειναι αντάξιο των προσδοκιών έστω και χωρίς dsd.
Jiovani75
