Set Ηχείων Tannoy 611-605 Crystal Audio CS120
Πωλούνται τα ηχεία του home cinema μου:
  • 2 Tannoy 611
    • Specifications :
      Peak Power/Channel.............................250 Watts
      Recommended Amp Power....................10-150 Watts
      Frequency Response +/-3dB...................45Hz-30kHz
      Nominal Impedance................................6 ohms
      Minimum Impedance..............................4 ohms
      Sensitivity (2.83V @ 1m)........................91dB
      Cross-over Frequency.............................400Hz & 2.5kHz
      Cross-over Type.....................................First Order Low Pass / First Order High Pass
      Terminals..............................................Gold plated, Bi-wired
      System Type.........................................Closed Box
      Internal Volume......................................22.9 Litres
      Drive Unit Complement............................8" Dual Concentric & 8" Bass Unit
      Dimensions(w x d x h)............................41.5 x 31 x 76.5 cm
      Weight..................................................14kg per sideσε άριστη κατάσταση!
  • 2 Tannoy 605 με κάποια σπασίματα πλήρως λειτουργικα
    • Specifications :
      System Type...................................Ducted port
      Terminals........................................Bi-wired
      Drive Units.......................................2.5cm gold anodized aluminum tweeter
      .......................................16.5cm bass unit
      Peak Power.....................................150 watts per channel
      Sensitivity........................................87dB/2.83V/1 meter
      Crossover Frequency........................3kHz, first order high pass
      Internal Volume................................10.5 liters
      Recommend Amplifier Power............10 to 90 watts per channel
      Frequency Response........................55Hz to 30kHz
      Nominal Impedance..........................8 ohms (Minimum 6 ohms)
      Dimensions(w x d x h)......................40 x 27.6 x 18.8 cm
      Weight............................................7kg each
  • 1 Crystal Audio CS-120 σε αριστη κατάσταση
    • Max Power 100W Nominal Impedance..........................8 ohms
  • 2 Βασεις ηχείων δαπέδου
  • 2 Βασεις ηχειων Vogels VLB200 σε αριστη κατασταση
Brochure: http://www.hilberink.nl/tannoy2/tannoy_sixes_series.pdf
Τιμή για όλα τα ηχεία και όλες τις βάσεις είναι 300euro.
ΥΓ. Για να μην υπάρχουν παρεξηγησεις η τιμη αφορα τα 2 611 & το CS120. Εαν κάποιος θελει μόνο αυτά, τα 605 θα τα χαρήσω σε ξεχωριστη αγγελία.
giannis9494
