Sharp SD-HX500 Digital AV Receiver and Universal Player
Price: $749.95
Description
Thin-profile, nuanced styling and flat-panel design concept that complements Sharp's AQUOS LCD TVs
Transparent elements and aluminum panels contribute to a high-sense design that complements any interior decor.
Thin-profile design measuring only 3.6" in depth* enables wall-mounting along with the AQUOS.
. 5.6-MHz "1-Bit Digital Amplifier" delivers precise, impressive, "concert-hall" realism
Super-high-speed sampling at 5.6 million times per second (5.6 MHz) yields a dramatic improvement in audio resolution, reproducing the speed and smoothness of a sound's attack with the highest quality and achieving more realistic reproduction of dialog and atmosphere in film soundtracks.
Amplifier section features high-performance design using glass-epoxy PC (printed circuit) boards to deliver superb quality audio.
Gold-plated pin jacks and banana-plug-compatible speaker terminals provide high-quality connections for no-compromise audio reproduction in any setting when the 1-Bit Audio Amplifier is teamed with high-end speakers.
Built-in multi-disc player for playback of SACD/DVD audio, DVD video, and other disc formats
Supports playback of SACDs and other discs including DVD Audio, DVD Video, DVD-RW (VR/video mode compatible), DVD-R, audio CDs/CD-R/CD-RW and MP3-encoded.
Built-in progressive-scan circuit allows high-quality playback of DVD video.
Horizontal resolution DVD: greater than 500 lines
Video signal Conforms to NTSC color standard
Tuner circuit system Quartz digital synthesizer system
FM/AM tuner
Inputs/Outputs:
Video output jacks Video output
S-Video output
D1/D2 video output
Composite video output
Audio output jacks Digital output: Optical (player output for projector)
Audio input jacks Digital input: Optical (external audio input)
3 Analog inputs: Pin jack (L/R)(TV/video/external input 2)
2 System jacks Special square terminals
Amplifier:
Maximum rated power output 600 W total (in 4 )
Front: 100 W + 100 W
Center: 100 W
Surround: 100 W + 100 W
Sub-woofer: Line out
1-Bit sampling rate 5.6-MHz
Audio output jacks Speaker output: 4 to 8 (banana-plug compatible, 6 channels)
Sub-woofer output: Pin jack
Power supply 100-V AC, 50/60 Hz
Dimensions:
Amplifier:
Size: 10.53" (W) x 6.6" (H) x 4.56" (D)
Weight: 11 lbs
Main Unit:
Weight: 7 lbs
Supplied Accessories:
Remote control
AAA batteries
System connecting cable
Video cable
FM antenna
AM loop antenna
User Manual
Warranty card
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
πάντως σαν πακέτο είναι εντυπωσιακό....
Για ένα μικρό χώρο είναι υπέρικανοποιητικό...
από ήχο τώρα....
Υπάρχει σε τέτοιο σχέδιο σε player μόνο ? Έχω μία 20" LCD που την έχω κρεμάσει στον τοίχο και θέλω να βρώ ένα όρθιο player που να μπορεί να μπέι στον τοίχο. Κάποιοι μου έχουν προτείνει το playstation αλλά δεν είναι κάτι που θα ήθελα να πάρω.
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
αν θυμάμαι καλα η sharp στο παρελθόν είχε παρουσιάσει κάτι τέτοιο, αλλά και η Sony. Και αν θυμάμαι καλά κάποιος συν-λίστης είχε ρωτήσει κάτι παρόμοιο στην κατηγορία των dvd, και εκεί είχαν αναφερθεί τα ανάλογα μοντέλα. Οπότε με μια μικρή αναζήτηση στην κατηγορία dvd θα πάρεις την απάντησή σου...
Το θυμάμαι το συγκριμένο post. Οσο για το player της Sony έχει εξαφανισθεί και σε όσα μαγαζιά ρώτησα δεν υπήρχε τίποτα σχετικό. Δίχνει πολύ περίεργο να προοθούν slim τηλεοράσεις και να μην βγάζουν DVD players που μπορούν να κρεμαστούν στον τοίχο.
Σπύρος Μπλάτσιος said:
άσε...δεν θέλω να συγχίζομαι πρωί-πρωί
Τι έγινε Σπύρο?
Και στην CarAudio έγραψες αντίστοιχα......
Γιατί παλικάρι μου?
Τι σου έκαναν?
Να βαρέσω κανέναν? :wink:
kchannel
