Shindo Masseto tube preamplifier
Κώστας Φ.
Specifications:
  • Phono Input: Switchable
  • Phono MC Input Sensitivity/Impedance: 0.2mV/2-100Ω
  • Phono MM Input Sensitivity/Impedance: 5V/47KΩ
  • Output/Impedance: 5V/600Ω
  • Phono Max. Input Voltage: 1,200mV
  • Signal to Noise Ratio: 119dB
  • Frequency Response: 20 – 20,000Hz
  • Power Requirements: AC 120V or 220 – 240V 50/60Hz
  • Power Consumption: 80W
  • Dimensions: W 13.8 ×H 4.7 ×D 12.2 inch
  • Weight: 17.6lb
  • MSRP: $11,500
"The Masseto is the newest preamplifier from Ken Shindo, falls right in between the $7,900 Monbrison and the $16,000 Vosne-Romanee. It's designed around a special Telefunken LCP86 triode/pentode vacuum tube, and it uses one such tube per channel in the line stage, and they are mounted in a quaint little arched window in the front panel. The phono section has one Philips 6189W and one 12AT7 tube per channel. The Masseto has a dual power supply based on a pair of Philips 6X4WA rectifier tubes. There are also lots of other new old-stock parts like oil caps, and the like.
After spending many, many hours in the last year and a half listening to different Shindo preamps, it is my humble, but informed opinion that there is something about them that sets them above the rest if your goal is to emotionally experience music in your home. The question of which one is simple. Buy the best one you can afford. The Aurieges is plenty good enough to let you build an outstanding system around it. After you get the other equipment you want, then the sky or the wallet's the limit."
Full Review: Dagogo.com
Ημίθεος
Άθλιο. Ακόμα και ένας ακραιφνής οπαδός του Λένιν θα το είχε φτιάξει πιο όμορφο.
Κώστας Φ.
Απάντηση: Shindo Masseto tube preamplifier
Eίστε υπερβολικοί.
Στα 80-φεύγα μου, με την "αποκλειστική" να με ξεχ3ζει, μπορεί και να μου αρέσει! :mrgreen:
Tό σχεδιαστικό του Πλεύρη διαθέτει καλύτερους στυλίστες ?
Ετσι γιά τήν Ιστορία , τά τεχνολογικά επιτεύγματα του Υπαρκτού Σοσιαλισμού υπήρξαν κλάσεις ανώτερα από αυτά τού Ιμπεριαλιστικού Μακαρθικού σκοταδισμού καί πάντα στόχευαν στήν εξυπηρέτηση τών αναγκών τών λαών καί όχι στόν άκριτο καί άκρατο καταναλωτισμό γιά νά πλουτίζουν οι πολυεθνικές καί τά μονοπώλεια.
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Απάντηση: Re: Shindo Masseto tube preamplifier
Μην τα λες έτσι απότομα γιατί θα τρέχω να πουλήσω το μοντέο και να αγοράσω κανένα τράμπαντ...
(αν έχεις υπόψιν και κανένα χάι έντ ενισχυτή Made in CCCP θα με υποχρεώσεις)
Ημίθεος
Μη με αποπαίρνεις. Σκέψου μόνον πως μου είναι αδύνατο να σκεφθώ ως κομμουνιστής, και ούτε θα μπορέσω να γίνω ποτέ τέτοιος, ακόμη κι αν το θελήσω, καθώς ο δείκτης νοημοσύνης μου είναι μεγαλύτερος του 25.
1) Ο δεικτης νοημοσυνης ειναι Αμερικανικη Ρατσιστικη εφευρεση στην προσπαθεια να αποδειξουν οτι οι μαυροι Αφροαμερικανοι ειναι περιπου ζωα.
Καλο ειναι να μην σιγονταρουμε και μεις σε κατι τετοια, την στιγμη μαλιστα που τον εχουν αμφισβητησει τα πιο προοδευτικα στοιχεια της Αμερικανικης κοινωνιας.
2) Ο προενισχυτης δεν εχει καμμια σχεση με Ρωσικο - Σοβιετικο Τεχνολογικο κατασκευασμα, που παρα την λιτη τους εμφανιση δεν εχουν καμμια σχεση με τα Δυτικα παιχνιδακια. Εχω αρκετη πειρα απο Ρωσικα μηχανηματα κυριως απο τον χωρο των Τηλεπικοινωνιων. Συγκρινομενα με τα δυτικα ειναι πιο μεγαλα, πιο βαρια, αποτελεσματικοτατα, ανθεκτικοτατα, λειτουργικοτατα, δεν βγαζουν βλαβες, εχουν υψηλη επισκεψιμοτητα και επισκευασιμοτητα, ειναι γκριζα ή κρεμ, ποτε δεν ειναι πρασινα, και για να γυρισεις ενα διακοπτη πρεπει να εισαι Αντρας και να το εννοεις.
Το αισθητικο τους μερος ειναι ανυπαρκτο, αλλα out there οι προτεραιοτητες ειναι αλλες.
Τουλαχιστον εχουν χαριτωμενες ονομασιες μοντελων οπως Ακαντέμικ Ζορόνωφ ή Ουζουνιήτσκι Ζαλιήβ ή Πάλιουμπα Ναγιάδα. :crazy_3:
Κώστας Φ.
Eίδατε πόσα χρόνια άντεξε ο MIR;! :smoking:
Την άποψή μου περί κομμουνισμού θα την βρείτε στην υπογραφή μου, αλλά η αλήθεια να λέγεται.
Κώστας Φ.
τελικά ο αριστερός χαϊεντισμός ή ο δεξιός ειναι καλύτερος;
Aυτά είναι ξεπερασμένα.
Τώρα έχουμε περάσει σε εποχές emo χαϊεντισμού και trendy χαϊεντισμού. Οι κάγκουρες παίζουν με προβολείς και δεν τους δίνουμε σημασία. )(
[για να γυρισεις ενα διακοπτη πρεπει να εισαι Αντρας και να το εννοεις]
Tωρα καταλαβαινω γιατι δεν υπαρχουν κουμουνιστριες χαιεντουδες
ΥΓ.Και η βαριοπουλα θελει ανδρα, αλλα πιστευω το κομπρεσερ ειναι πιο εξελιγμενο
[τά τεχνολογικά επιτεύγματα του Υπαρκτού Σοσιαλισμού υπήρξαν κλάσεις ανώτερα από αυτά τού Ιμπεριαλιστικού Μακαρθικού σκοταδισμού καί πάντα στόχευαν στήν εξυπηρέτηση τών αναγκών τών λαών]
το μεγαλυτερο τεχνολογικο επιτευγμα ηταν το τειχος του Βεοολινου και η Ανοιξη της Πραγας εγινε για την εξυπηρέτηση τών αναγκών τών λαών
TehLooney
