Sierra Audio
WHITNEY POWER AMPLIFIER
WHITNEY SPECIFICATIONS
STEREO
DIFFERENTIAL
Power Output into 8 Ohms:
2 x 120 W 1 x 460 W
Power Output into 4 Ohms: 2 x 240 W 1 x 920 W
Power Output into 2 Ohms: 1 x 1420 W
Input Impedance: 100 K Ohms single ended
2200 Ohms balanced
Power Supply Capacitance: 188,000 ΅F
Slew Rate 70 volts / ΅ second
Power Transformer(s): 1 x 1000 VA
Dynamic Headroom db: 0.5 db
Total Harmonic Distortion (THD) <0.001%
Size HxWxD 7.5" x 17" x 14"
Weight: 50 lbs / each
MSRP: $3,495 / each
DENALI POWER AMPLIFIER
DENALI SPECIFICATIONS
STEREO DIFFERENTIAL
Power Output into 8 Ohms: 2 x 160 W 1 x 600 W
Power Output into 4 Ohms: 2 x 320 W 1 x 1200 W
Power Output into 2 Ohms: 1 x 1900 W
2200 Ohms balanced
Power Supply Capacitance: 170,000 ΅F
Power Transformer(s): 1 x 2260 VA
Power consumption: 400 Watt idle / 2000Watt Max
Size HxWxD 11" x 19" x 16"
Weight: 115 lbs / each
MSRP: $6,995 each
EVEREST POWER AMPLIFIER
EVEREST SPECIFICATIONS
STEREO DIFFERENTIAL
Power Output into 8 Ohms: 2 x 300 W 1 x 1200 W
Power Output into 4 Ohms: 2 x 600 W 1 x 2400 W
Power Output into 2 Ohms: 1 x 3750 W
2200 Ohms balanced
Power Supply Capacitance: 180,000 ΅F
Power Transformer(s): 2 x 2100 VA
Power consumption: 500 Watt idle / 4000Watt Max
Size HxWxD 11" x 19" x 23"
Weight: 180 lbs / each
MSRP: $9,995 each
Κωνσταντίνος Παντός
