SIM2 Nero 3 LED-DLP Projector
SIM2 came to CEDIA this year with an LED-illuminated, single-chip DLP projector, the Nero 3, which uses red, green, and blue LEDs instead of a traditional lamp. Because the LEDs can be cycled on and off very quickly, there is no need for a color wheel, and there is no rainbow effect.
It achieves the equivalent of 2000 ANSI lumens and a dynamic contrast ratio of 100,000:1 by modulating the LEDs—no mechanical iris. The LEDs also offer a wide color gamut—125% of NTSC—and it can also reproduce BT.709 and DCI/P3. In addition, it provides manual lens shift, which is unusual for SIM2, but no lens memories—you need to add an anamorphic lens for 2.35:1 screens. Rounding out the features is 3D capability with RF active-shutter glasses.
In the demo, two projectors were compared—the Nero 3 and the Sirio, a single-chip DLP with dual UHP lamps, which achieve a peak brightness of 7000 lumens. Both projectors were set up with the basic picture controls but not fully calibrated. They were firing onto a Vutec XVH1 2.35:1, 160-inch-wide screen with a gain of 1.0. Also in the room was a Dolby Atmossound systemwith a Denon receiverand Atlantic Technology Atmos-enabled speakers, and SIM2had installed reflective panels on the ceiling of the sound room, which was otherwise very absorptive.
the Nero 3ain't cheap—$14,000 is a lot for a single-chip 1080p DLP projector
14K γι αυτο το προβολι, οταν ο ανταγωνισμος εχει φτασει πλεον σε αλλα επιπεδα και με καλυτερες τιμες?...αν ηταν "3τσιπικος" να το συζητουσαμε...τι "πινουν" εκει στη SIM2?
απο εδω...
In this composite shot of a sand mandala, the upper image is from the Sirio, and the lower one is from the Nero 3. Notice the striking difference in color.
In this shot, notice the difference in skin tone between the Sirio above and Nero 3 below.
Αυτές οι εταιρείες δεν απευθύνονται στον ψαγμένο χομπίστα, γι' αυτό και ζητάνε ό,τι θέλουν.
Άλλο κοινό και άλλες τιμές. ;)
Η αλήθεια ειναι κάπου στην μέση .
Για ρωτήστε και κανένα καλιμπρατορα για την συμπεριφορά τους στο καλιμπραρισμα και ασχέτως χρημάτων τι θα επιλεγανε να έχουν σπιτι τους ...
marina zakalka
