SME Model 2 Tonearm
Dimensions M2-9 M2-10 M2-12
mm ins mm ins mm ins
Nominal length,pivot stylus (A) 233.20 9.18 239.30 9.42 308.80 12.16
Distance from bedplate centreto turntable centre (B) 215.40 8.48 222.00 8.74 295.60 11.64
Cartridge fixing centres (C) 12.70 0.50 12.70 0.50 12.70 0.50
Overhang (F) 17.80 0.70 17.30 0.68 13.21 0.52
Height above mountingsurface (G)
max 87.00 3.43 87.00 3.43 87.00 3.43
min 63.00 2.48 63.00 2.48 63.00 2.48
Note: When the turntable surface is more than 41.30mm (1.625”) above the surface on which the arm is mounted a P1 spacer, SME Part No. 3823/IV, is required
Mounting surface to underside of headshell (H)
max 67.40 2.65 67.40 2.65 67.40 2.65
min 43.40 1.71 43.40 1.71 43.40 1.71
Depth below mountingsurface (J) 46.00 1.81 46.00 1.81 46.00 1.81
Balance weight radialclearance (K) 51.00 2.00 51.00 2.00 51.00 2.00
Tracking adjustment ± 12.70 0.50 12.70 0.50 12.70 0.50
1.0 gram per revolution tungsten weight sub-graduated 0.25 and 0.025 gram moving on a precision screw with backlash eliminator
1220mm (48”) D501 balanced audio lead. Engineered in the best camera quality with satin chrome finish
Fluid damped lift/lower control
Geometry optimised for Ψ300mm (12”) LPs
Low friction, fully shielded races for both axes
Phono plugs and other contacts heavily gold plated
Pressure die-cast magnesium headshell with unique collet
Sliding base for tracking adjustment
Thin-walled stainless steel tonearm with internal damping
Thumbwheel height adjustment
Traditional pattern anti-skate
leftos
