Softone's AUDIO PRODUCTS
Model3?@CD?@Player?@/?@CD?@Transport
The specification
Price US$1500.00(exclude tax and carriage)
Analog output Unbalanced Consumer Output(RCA)
Analog output Voltage 2V ( at 0db digital signal reproduction)
Frequency Response 20Hz - 20KHz (-1.0db)
Digital outputs 75 Ohm SP/DIF(RCA), Toslink Optical.
CD compatibility 12cmCD, 8cmCD, CD-R
Attachment IR remote control handset
Dimension width 12"(30cm), depth 10"(26cm), height 4"(10cm)
Weight 15 lbs (7kg)
AC Power Requirements 117-120Volts 50-60Hz or
220-230Volts 50-60Hz. (choose at the order) 40W
Model_2
TUBE Digital to Analog Converter
The specification about Model_2
Price US$650.00(exclude tax and carriage)
Digital inputs 75 Ohm SP/DIF(RCA), Toslink Optical.
Sampling 32KHz to 96KHzA16bit to 24bit
Error watch Display of 7 kinds error, 4 digits error counter
Analog output Voltage 2V( at 0db digital signal reproduction)
Tubes 6DJ8 x 2
Dimensions width 12"(30cm), depth 10"(26cm), height 4"(10cm)
Weight 10 lbs.(4.5Kg)
AC Power Requirements 117-120Volts, 50-60Hz or
220-230Volts, 50-60Hz.(Choose at the order.)
40W
Κωνσταντίνος Παντός
