Μία από τις ποιοτικότερες λύσεις για software mastering προτείνει η Sonalksis, τη Mastering Suite.
Extended information
- MultiLimit - Multiband Mastering Limiter
MultiLimit is the absolute pinnacle in mastering limiting, a superior processor for the most demanding user enabling precision control as you rebalance mix dynamics across the entire frequency range.
- MaxLimit - Maximizing Mastering Limiter
MaxLimit, a program maximizing limiter for when you need to push your material or your mix a little further introducing a unique 'smoothing' feature which allows direct control over the balance between limiting transparency and volume maximisation.
- StereoTools - Stereo Imaging Processor
StereoTools is a complete stereo imaging, metering and manipulation tool, providing detailed visual feedback of frequency, phase and positioning information. The plug-in has numerous display options which enable precision image monitoring and processing during the mastering stage.
- Ultimate-D - Ultimate Dithering
Ultimate-D is a new paradigm in re-quantization. It combines advanced digital resolution enhancement processing, with an innovative and totally unique interface that uses intuitive parameters, so unlike traditional re-quantisation processors. Supreme simplicity, united with unparalleled quality.
