Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
So what is it?
Well the BardOne system is a high end digital wireless sound distribution system and comes as a set, Tx and Rx which stands for transmit and receive.
How does it work?
Plug the BardOne Tx into the music source be it a CD player, a radio or PC via phono leads.
Plug the BardOne Rx into an amplifier or active speaker system within range of the transmitter.
Set both the Tx and Rx modules to the same transmit channel (up to 8 stereo to choose from).
Make sure everything is switched on.
Press play on the music source.
Enjoy the music.
As the music is transmitted digitally using the 2.4GHz band it can be transmitted in high end, uncompressed quality and in real time.
Multi-room.
Add more Rx modules, connect them to more amplifiers or active speaker systems, set them to the same channel and distribute your music wirelessly throughout your home.
It really is that simple!
Eight Stereo Channels.
There are eight stereo digital channels to choose from, so in principle you can have eight stereo music sources transmitting. Just set your BardOne receive module to the channel you want and listen.
Number One.
The BardOne, as the name implies, is the first in a range of Bard products from Sonneteer. Soon there will be the BardUSB transmitter to accommodate PC music more readily, as we expect the home PC to grow as the centre of the home entertainment system. So let’s make it high end.
One thing’s for sure, we will keep it simple.
-Specifications-
-Digital wireless transmission for high end sound quality.
-Up to 8 zones of stereo CD quality sound.
-Suitable for multi room installations.
-Discrete cream coloured paintable housing.
-Transmit Range 20-40 metres (L.O.S.)*
-Multiple receivers.
-Phono RCA connectors for input and output.
-Operating Frequency of ISM band 2.4-2.4835GHz.
-Avoids reception errors by employing forward error correction.
-Omni directional Embedded antenna.
-9 to 12V DC power operated.
-Supplied with mulit-head universal power supply (100-250V a.c.).
