Κώστας Φ.
"The Elipsa is a three-way design. A 1" ring-radiator tweeter sits 36" from the floor, mounted very close above a 6" pulp-cone midrange driver, the diaphragm of which has a concave dustcap to continue the smooth profile. The midrange driver handles a wide range, 250Hz –2.3kHz, and is acoustically loaded within its own elliptically shaped subenclosure, this vented to the speaker's rear with a 2.25"-diameter port. Whereas the Cremona has twin 6" woofers, the Elipsa uses a single 10" woofer, the cone of which is formed from an alloy of magnesium and aluminum. This driver is acoustically loaded by two 3"-diameter flared ports on the cabinet rear and, rather than a dustcap, has a stationary metal phase plug on the front of its central pole piece.
The crossover is specified as using second-order slopes. Electrical connection is via a single pair of high-quality binding posts at the base of the cabinet rear, beneath the lowest of the three ports and set, like them, on a leather-covered panel. The black metal bottom plate can be fitted with spikes of differing lengths front and back to allow the speaker to be raked back.
Summing Up
It is not quite without character —that slightly warm upper bass and slightly forward mid-treble will need some adjustment in system setup and/or choice of ancillaries —but Sonus Faber's Cremona Elipsa is, overall, a superb performer. It also looks stunningly beautiful. If you can stretch your budget by 50% for the Amati anniversario and be prepared to work harder to integrate it in your room, that might be, overall, the better choice. If not, the Cremona Elipsa is a loudspeaker for which no apology need be made." -- John Atkinson
"Overall, I was impressed by the Sonus Faber Cremona Elipsa's measured performance. It demonstrates some excellent loudspeaker engineering, although, as with some other expensive loudspeakers, I do wonder if a simpler low-frequency arrangement might produce more consistent results. But this is a minor quibble, considering how fine the speaker sounds." -- John Atkinson
Full Review: Stereophile.com
