Sony Bravia VPL-VW80 SXRD
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Sony’s new BRAVIA VPL-VW80 SXRD projector is designed to be the next logical step for the serious Home Cinema enthusiast. At its heart lies Sony’s SXRD™ (Silicon X-tal Reflective Display) panel technology that delivers exquisitely fine-grained 1080p Full HD for a truly cinematic experience. The special High Frame Rate SXRD panels and exclusive Motionflow Dark Frame Insertion system double the frame rate to 100Hz for fluid, natural movement no matter how fast the action gets. Eight-stage real-time signal processing by Sony’s BRAVIA ENGINE 2 ensures outstanding colour and visibly superior overall image quality.
The core of the BRAVIA VPL-VW80 is its High Frame Rate triple SXRD™ panel array which can operate at 100 fps – double the norm - for exceptionally smooth on-screen action. SXRD delivers the full 1920 x 1080 resolution demanded by Full HD with cinematic clarity and precision thanks to its super-fine panel micro-architecture. 7µm pixels spaced just 0.25µm apart produce an image completely free from the ‘screen door’ pixel grid effect that can undermine other projection systems. The 2.5ms response time makes a further contribution to the overall impression of fluid, natural movement essential for a convincing recreation of the cinematic experience.
The projector uses Motionflow Dark Frame Insertion to deliver on the potential offered by the High Frame rate SXRD panels. Motionflow itself works by creating intermediate frames from the original video source and inserting them to double the number of images displayed every second. The unprecedented level of accuracy with which this is done ensures that what you see on the screen is a seamless, perfectly crisp and smoothly moving image.
Dark Frame Insertion enhances the effect of Motionflow. The optional insertion of darkened frames heightens the contrast and eliminates any judder – the jerky picture that can occur when the camera pans – by allowing the eye ‘space’ to blend one frame into the next. This action mimics that of actual movie projection and functions best in the darkened environment of a Home Cinema.
Contrast is central to superior picture quality, so the innate high contrast of SXRD is leveraged by Sony’s Advanced Iris 2 system to produce a super-high contrast ratio of up to 60,000:1. Advanced Iris 2 works in real time to analyse each scene and adjust the aperture dynamically to achieve the best possible picture. It prevents detail being lost to the shadows in dark scenes, while brightly lit sequences are prevented from washing out.
To ensure the best possible results, the VPL-VW80 features electronic panel alignment allowing users to achieve an exact alignment of the red, green and blue elements within each pixel. This can be done full screen or by selecting specific zones for pinpoint adjustment. The result is an image with no trace of fuzziness or colour bloom along the edges of objects.
When it comes to colour, the first stage in ensuring excellent reproduction is carried out by the BRAVIA ENGINE 2, which optimises every frame for vibrant and lifelike results. If additional adjustment is necessary, Real Colour Processing (RCP) provides a precision toolkit for getting the right results. Crucially, Real Colour Processing allows you to adjust the hue of a specific colour without changing the whole image. So if something like skin tone needs tweaking, you can do it without altering the colour of the sky or the background of the scene.
The BRAVIA VPL-VW80 provides full support for the xvYCC colour space, the new industry standard encompassing a range nearly two times wider than the existing sRGB standard. Like all Sony products with this capability, it bears the x.v.Colour sub-brand, indicating to customers that it is ready for a future where the phrase ‘lifelike colour’ will take on a new depth of meaning.
In addition, the BRAVIA VPL-VW80 also offers Deep Colour™, which increases the number of colours available within the boundaries defined by x.v.Colour from millions to billions. Again, like x.v.Colour, this readies the projector for exciting developments in the way in which colour is captured and reproduced. Right now, the best way to appreciate the effects of Deep Colour™ is with Playstation™ 3 – new games will use it to push the boundaries of realism to ever-higher levels.
Full HD images generated by the projector are built up of millions of pixels, each only 7µm across. Whilst this is key to the impressive realism of the picture, it requires an excellent lens or detail will be lost. The VPL-VW80 is equipped with the All Range Crisp Focus (ARC-F) lens which has the necessary superior resolution and focus characteristics. The lens offers a 1.6x motorised zoom and both vertical and horizontal adjustment, making it easy to set the projector up and achieve a good picture in a variety of environments. To keep the lens in perfect condition it has a motorised cover which automatically opens when the power is turned on, and closes again at power-down.
The inclusion of twin connectors with HDMI™ technology opens up another dimension for the VPL-VW80. It makes it possible to connect to video sources like Blu-ray Disc™ players which offer exact, 24 frame-per-second replication of the cinematic original. As the projector has the ‘24p True Cinema’ function, it can display films exactly as they were first recorded. By contrast, conventional transfers to DVD employ a higher frame rate and run approximately 4% faster than the original, affecting both the picture quality and the pitch of the soundtrack.
HDMI™ CEC technology also allows control of multiple devices from a single remote in a process called BRAVIA Theatre Sync. One Touch Play lets you insert a disc and press Play, at which point the whole Home Theatre system, including the projector, powers up automatically and the film starts. Conversely, System Stand-By shuts down all HDMI-connected elements of the system at a single press of the Power/Standby button on the remote.
The attention to detail – and getting it right – extends all the way to this sometimes neglected peripheral. The remote makes use of large buttons for easy operation of key functions, and features a backlight so you don’t need to turn the lights up and spoil the atmosphere.
Home Cinema enthusiasts in search of perfection will no doubt be drawn to the Anamorphic Zoom function. This uses sophisticated signal processing of widescreen modes together with an optional third-party anamorphic lens to recreate the immersive 2.35:1 CinemaScope aspect ratio normally only seen in the cinema. One of the the two Trigger Out terminals handles Anamorphic Zoom mode; the other is for power.
One last thing worth noting about the VPL-VW80 is something you cannot even see, but that makes a crucial difference to the viewing experience. Thanks to a fan assembly specially designed by Sony that runs almost noiselessly on a non-contact spindle, the projector is whisper-quiet, emitting less than 20dB when running.
“With the VPL-VW80 we are offering customers genuinely high-end features in a top mid-segment model,” says Josh Honda, Senior Marketing Manager at Sony. “This means real baseline quality plus fine control where it matters, like Motionflow Dark Frame Insertion and detailed panel alignment. This will appeal to the knowledgeable buyer keen to upgrade to HD or improve an existing HD setup – and who wants to do it properly.”
The BRAVIA VPL-VW80 now forms the centrepiece of the BRAVIA HD Home projector range. For those joining the HD revolution there’s the more affordable VPL-HW10 with its ideal balance of ease of use with very high image quality; an entry HD model with great cinematic features. At the top end, the VPL-VW200 combines a full cast of the most sophisticated image technologies with a Xenon lamp and a Carl Zeiss lens.
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
VPL-VW80 Key Features
<table border="1" width="550"> <tbody> <tr style="background-color: rgb(7, 7, 135);"> <td>OPTICAL</td> <td>
</td></tr> <tr> <td>Panel resolution</td> <td>Full HD 1920 x 1080</td></tr> <tr> <td>Pixels</td> <td>6,220,800 (2,073,600 x 3)</td></tr> <tr> <td>Pixel size/inter-pixel spacing</td> <td>7um/0.25=m</td></tr> <tr> <td>Panel technology/size</td> <td>New High Frame Rate Sony SXRD™/0.61-inch</td></tr> <tr> <td>Panel response time</td> <td>2.5 milliseconds</td></tr> <tr> <td>Lens type</td> <td>ARC-F (All Resolution Crisp Focus)</td></tr> <tr> <td>Lens zoom ratio</td> <td>1.6x (motorised incl. Lens cover)</td></tr> <tr> <td>Lens shift</td> <td>Vertical 65%, Horizontal 25%</td></tr> <tr> <td>Contrast</td> <td>60,000:1</td></tr> <tr> <td>Brightness / Lamp</td> <td>800 ANSI Lumen, 200W UHP</td></tr> <tr> <td>Screen size (16:9, diagonal)</td> <td>40”-300”/1m-7.6m</td></tr> <tr> <td>Throwing distance (16:9) 80”</td> <td>2.63m – 3.89m</td></tr> <tr style="background-color: rgb(7, 7, 135);"> <td>FEATURES</td> <td>
</td></tr> <tr> <td>Picture Enhancement</td> <td>BRAVIA ENGINE 2 (fully digital)</td></tr> <tr> <td>Colour Enhancement</td> <td>x.v.Colour, Deep Colour</td></tr> <tr> <td>
</td> <td>Real Colour Processing (RCP)</td></tr> <tr> <td>Contrast Enhancement</td> <td>Advanced Iris 2</td></tr> <tr> <td>Connectivity Enhancement</td> <td>24p True Cinema, BRAVIA Theatre Sync</td></tr> <tr> <td>Panel Alignment Function</td> <td>Full screen: ±2.0 pixels in 0.1 pixel steps
Define zone from 16×9 point: ±2.0 pixels in
0.1 pixel steps</td></tr> <tr> <td>Special Noise Reduction</td> <td>Mosquito Noise, Block Noise Reduction</td></tr> <tr style="background-color: rgb(7, 7, 135);"> <td>INPUT/OUTPUT</td> <td>
</td></tr> <tr> <td>HDMI</td> <td>2 (CEC)</td></tr> <tr> <td>Component Video</td> <td>1</td></tr> <tr> <td>S-Video / Composite Video</td> <td>1 / 1</td></tr> <tr> <td>Input A, HD D-sub 15-pin</td> <td>1 (Analogue RGB, Component)</td></tr> <tr> <td>RS-232C: D-sub 9-pin</td> <td>1 (AMX Protocol supported)</td></tr> <tr> <td>Trigger Out</td> <td>2 (1 for Power, 1 for Anamorphic Zoom Mode)</td></tr> <tr> <td>Acceptable video signals
Via HDMI inputs:</td> <td>720/60p, 720/50p, 1080/60i, 1080/50i,
1080/60p, 1080/50p, 1080/24p</td></tr> <tr> <td>GENERAL</td> <td>
</td></tr> <tr> <td>Body colour</td> <td>Midnight Sky Black</td></tr> <tr> <td>Fan noise</td> <td>20dB</td></tr> <tr> <td>Dimensions (wxhxd)/Weight</td> <td>470 x 179.2 x 482.4mm / approx. 12kg</td></tr> <tr style="background-color: rgb(7, 7, 135);"> <td>ACCESSORIES</td> <td>
</td></tr> <tr> <td>Supplied Illuminated Remote
Control</td> <td>RM-PJVW80</td></tr> <tr> <td>Supplied Software</td> <td>Image Director3 (fine Gamma adjustments)</td></tr> <tr> <td>Optional replacement lamp</td> <td>LMP-H201, 200W UHP</td></tr> <tr> <td>Optional ceiling bracket</td> <td>PSS-H10</td></tr></tbody></table>
Απάντηση: Sony Bravia VPL-VW80 SXRD
Mονο εσενα;
Ολα ωραια , αλλα και με τα νεα μοντελα βλεπω να συνεχιζεται αυτη η χαμηλη φωτεινοτητα .
Μου φαινεται οτι η τεχνολογια των sxrd d-ila αδυνατουν να ανεβασουν την φωτεινοτητα.
Ενταξει στα πρωτα τους μοντελα αλλα πλεον νομιζω οτι δεν θα καταφερουν να βρουν λυση.
Αυτο ειναι ενα σοβαρο μειονεκτημα.
πιστευω οτι δεν εχει νοημα να εξοπλιζουν τα μηχανακια με ηλεκτρικα zoom focus και lens shift.ακριβαινει το κοστος χωρις νοημα αφου μια φορα τα σεταρεις και δεν ξανασχολεισε ασε που με το χερι φερνεις πιο ευκολα την ευκρινεια απο οτι σε ενα με μοτερ.
πατατιά εκανα που δεν πηρα διαρκειας για την Πανάθα......
....αφου καθε τρεις και λιγο στην PSA θα ειμαι!!!! :142::142::142:
DAMBO
