SONY NVX-P1 Portable Navigation Device
Νέο σύστημα από την SONY το οποίο λόγω μικρών διαστάσεων μπορεί να τοποθετηθεί εύκολα και γρήγορα στο αυτοκίνητο χωρίς να είναι απαραίτητη η χρήση πηγής με μεγάλη οθόνη.........
Plug-and-Play Ease
The street smart Portable Navigation Device (PND) is tailor-made for today's hectic lifestyle. Simply fit the cradle on your windscreen, slide in the PND - and you're ready to go.
NVX-P1 - A versatile co-pilot
If you're looking for a versatile co-pilot to save time and enhance your driving experience - consider a Sony NVX-P1 transferable navigation system. This portable model fits snugly into its own cradle on your windscreen and takes just moments to install or dismount, for easy transfer between vehicles and maximum security.
It gives you on-screen map guidance and Turn by Turn voice prompts in 8 languages* over its built-in speaker, and will quickly re-route you if necessary.
(* English, German, French, Dutch, Italian, Spanish, Swedish and Danish)
(σιγά μην είχαν για την Ελλάδα......... :( :( :( :cry: :cry: :cry: :cry: )
Know Europe like the back of your hand!
The NVX-P1 Portable Navigation Device features a 2 GB Hard Disc Drive (HDD) that comes pre-installed with comprehensive map data on 16 European countries** and an extensive database of places of interest including restaurants and hotels.
(** Available in Austria, Belgium, Denmark, Finland, France, Germany, Ireland, Italy, Luxembourg, The Netherlands, Norway, Portugal, Spain, Sweden, Switzerland, U.K.)
(μην ξαναλέμε τα ίδια........ :( :( :( :cry: :cry: :cry: :cry: )
Easy on the road
Switch on the NVX-P1 and you'll be welcomed by the intuitive GUI (Graphical User Interface). Simply input your destination as an address or postcode and you're off.
Select your destination from thousands of pre-installed places of interest as well as the 'favourites' you've installed. You can even set up 'way points' if making several stops en route.
Choose a range of display modes to visualise the route. Then just follow the on-screen instructions and voice prompts. Even if you miss a turn, the system will soon have you back on track.
Screen Guide features
With its high quality 3.8" display, user-friendly menu and stunning 2D or Virtual 3D maps, the NVX-P1 is streets ahead of your average navigator.
The screen guide features are as follows:
*Indicates the road you are driving on and your next task
*Crisp, bright 3.8" display - developed especially for in-car use
*Select between 3D (as in image) or 2D mode. 3D angle can be easily adjusted
*Built-in high definition speaker for crystal clear voice guidance in 8 languages
*Micro 2 GB HDD with map data on 16 European countries pre-installed
*Distance to turn. Also tells you the ETA, distance left to destination, speed and direction
*Ergonomic rubber, multi-function keys for easy operation
*Advanced built-in GPS antenna (12 channel with auto selection)
*Power plug to connect to supplied power adapters (home and in-car)
τιμουλα?
Γιώργο μόλις παρουσιάστηκε!!
Και δεν ξέρω αν θα το φέρουν Ελλάδα αφού δεν έχει χάρτες για εμάς............
Πιστεύω ότι θα μπορούσες εσύ (λόγω άμεσης επαφής... :roll: ) να μάθεις!!!
Θα ρωτήσω πάντως κι εγώ...........
Ioanniss
