Sony RX1R II
m1ts0s
News poster
FASTER AUTOFOCUS, A BUILT-IN EVF, AND A TILTING SCREEN
'The RX1R II is a tiny despite the relatively large fixed 35mm lens that it sports. The camera body itself is roughly the size of the company's other popular pint-sized camera, the RX100, and it feels nearly as light. The big difference between the two is that the RX100's retractable zoom lens makes it truly fit in a pocket, whereas the bulky, immovable f2.0 lens on the RX1R II means you'll have to carry the camera on a strap or in a bag.
But what you get at this size is a true powerhouse of a camera. The RX1R II has a 42.4-megapixel, full-frame Exmor R CMOS sensor. It's also backlit, allowing for an ISO range of 100-25,600 (expandable to 50-102,400). Sony's done a number of things to the structure of the sensor that ups the data transmission speed, making this version 3.5 times faster than the original RX1R.'
'Sony's built what it's calling the "world’s first optical variable low pass filter," which means that you can toggle how severely the low pass filter affects your image or turn it off completely. If you're shooting a shirt or a fabric that could cause moire, you can turn the low pass filter on and tweak the strength to your liking. If you're shooting a plain landscape scene with no wild patterns, you can turn it off and get the full detail from your sensor. (The camera can also take multiple images with the different filter levels, and you can choose after the fact.) '
'The RX1R II is a premium digital camera for still photographers, and because of that Sony is commanding a premium price — it will cost $3,300 when it hits store shelves in November.'
http://www.theverge.com/2015/10/14/9530499/sony-rx1r-ii-digital-camera-compact-full-frame-price
Kotsidis John
Photography
μια απο τις καλυτερες αν οχι η καλυτερη κομπακτ full frame μηχανη, στην νεα της αναβαθμιση!
Αναμενουμε πως και πως!
Christos Kourmouzoglou
