Προς πώληση χρησιμοποιημένος σε καλή κατάσταση. Πολλές δυνατότητες για τον ενισχυτή (2 phono, έξοδος πρό-τελικο, 100 damping factor).
Τιμή πώλησης 300 ευρώ συζητήσιμη.
Για άμεση επικοινωνία τηλ 6945754573.
Description
The Sony integrated stereo amplifier model TA-1150 is designed with the most advanced techniques for audiophiles who wish to build a true-fidelity sound reproduction system.
Sony pooled their vast experience in solid state technology to produce this integrated amplifier.
The TA-1150 provides the lowest possible distortion, superior signal to noise ratio, wide dynamic range and unexcelled damping factor.
You'll hear every sound delicately, naturally and brilliantly as never before.
Specifications
Power output: 30 watts per channel into 8Ω (stereo)
Frequency response: 15Hz to 80kHz
Total harmonic distortion: 0.1%
Damping factor: 100
Input sensitivity: 2mV (MM), 140mV (line)
Signal to noise ratio: 70dB (MM), 90dB (line)
Output: 140mV (line), 24mV (DIN), 0.8V (Pre out)
Speaker load impedance: 4Ω to 16Ω
Semiconductors: 26 x transistors, 3 x diodes, 2 x IC
Dimensions: 400 x 149 x 316mm
Weight: 8.3kg
Year: 1973
Description
Specifications
Damping factor: 100
Weight: 8.3kg
Year: 1973
36,1 KB Προβολές: 0
34 KB Προβολές: 0
32,7 KB Προβολές: 0
