New * SpiderBox 9900 HD
SpiderBox 9900 2CA 1CI USB PVR
Only £239
< HD9900 Feature >
- Supports MPEG-2, MPEG-4, H.264 and fully DVB compliant
- Satellite receiver
- 2 Slot smart card
- 1 Slots common interface for Viaccess, Irdeto, Cryptoworks, Nagravision, Conax,
Mediaguard and etc.
- DiSEqC 1.0, 1.1, 1.2 and USALS
- Aspect ratio adjustment 4:3 (16/9 crop), 4:3 (16/9 letterbox), 16:9 (4/3 pillar box)
-User friendly OSD and operation
- Total 10,000 Channels Programmable
- Multi-language audio support
Multi-language menu text support
- Favorite channel selections
- Parental Guide and rating control
- RF Modulator 21-69 range
- EPG (Provider Electronic Program Guide) for On Screen Channel Information
- On-Screen Display with 65,536 Colors
- Blind scan (Power Scan) & Powerful EPG
- Zoom Function in Pause
- Selectable output for 1080p, 1080i, 720p, 576p and 576i format
- CVBS & RGB Video Output via SCART
- USB 2.0 Host (Access to HDD, USB memory, Others etc)
- Upgrade Software & Update Channel Database through USB 2.0 Port and RS232
- MP3 File Play by USB 2.0
- PVR Ready via USB
- Recorded file play on PC
- Reservation Recoding by EPG function
- Multimedia file play by USB 2.0
- Home streaming
- You Tube Support
- Ethernet Connection.
Based on the STi 7111 CPU
This Box has the same Options as the 9000 series and has the same OSD, but is faster and with more features...
Only £239
< HD9900 Feature >
- 2 Slot smart card
Mediaguard and etc.
- PVR Ready via USB
- Home streaming
- You Tube Support
12,9 KB Προβολές: 59
