Stello U3
m1ts0s
News poster
USB Audio Class 2.0 compliant Asynchronous synchronization mode
High Speed Bit Perfect Audio Data Stream up to 192kHz sampling rates
Master clock Super low jitter 2 external clocks
Sampling Frequency 22.5792mHz/24.576mHz for multiples of 44.1kHz/48kHz sampling rates
Resolution Standard sample rates 44.1, 88.2, 176.4, 48, 96, 192kHz/24bits
Audio Input 1 USB 2.0, Type B connector
Outputs Galvanic Isolated, Up to 192kHz sampling rates
1 COAX 75 Ohms, Gold Plated RCA Connector
1 AES/EBU 110 Ohms, Neutrik XLR Gold plated contacts
Lock indicator LED on the front panel
Platform Support Customized Windows Driver : Windows XP, Windows Vista, Windows 7
Natively supported by Apple Mac OS X
Dimension 100 X 36 X 100mm (WHD)
495 δολλάρια
http://www.aprilmusic.com/eng/main/sub02_03_05.html
m1ts0s
News poster
Απάντηση: Stello U3
USB to S/PDIF converter το μηχανάκι, σε αρκετά καλή τιμή απ'ότι βλέπω
dark2030@
