Studio Electric T3 Loudspeaker
Κώστας Φ.
The T3 is a floor standing, 3-way loudspeaker. The heart and soul of the design is the 6.5 inch broadband drive unit (encased in a stainless steel sphere) handling frequencies from 50 Hz to 4Kz. A side firing 8" sub woofer adds deep bass in a single octave from 25Hz to 50Hz. A hand selected silk dome tweeter provides extension into the upper harmonics.
Specifications:
LF: 8 inch gel coated composite
MF: 6.5 inch copolymer
HF: .75 inch silk dome
Response:
(+/-2db) 39Hz to 18KHz
(+/-4db) 34Hz to 22KHz
Impedance: 4 ohms
Sensitivity: 87db
Crossover:
PC mounted, asymmetrical design,using custom inductors/ Solen and Kimber capacitors / non inductive resistors.
Recommended Amplifier Power:
15W min*
150W max long term
450W peak
* Best results with at least 50W input.
SUGGESTED RETAIL PRICE:
$7900 for the pair
Σελίδα κατασκευαστή: Click
argiristheo
