V
VIDEOMIX
Την γνώμη σας, την άποψή σας για τα SUBWOOFER 210 και 212 της Αγγλικής
FB 210 Subwoofer
Frequency Response: 25Hz-140 Hz +3dB
Crossover: 40-140Hz variable
Power: 250 watts
Drive Units: Two 10" C-CAM woofers
Dimensions: 20.1" x 14.2" x 14.2"
Weight: 55 lbs.
Warranty: Three years
Price:$999
The newest addition to the Silver S line is the FB 210 subwoofer. It uses a pair of 10" C-CAM drivers, one forward-firing, one bottom-firing. The 55-pound bass-reflex cabinet is double-ported directly below the forward driver. A built-in 250W MOSFET amp supplies power. The sub is highly configurable, with speaker-level and line-level inputs, fully adjustable phase contouring, and a 40Hz -140Hz high-pass crossover. The A/V switch provides a 3dB boost in the 30Hz range and should appeal to those budding young astronauts clamoring for the ultimate in launch-pad realism. The IEC socket allows power cord swapping if desired. All Silver S Series speakers are equipped with gold-plated biwireable terminals and are magnetically shielded. With sensitivity hovering in the 91dB range, they proved an easy load for the variety of AVRs and amplifiers I had on hand.
212
FB 210 Subwoofer
Power: 250 watts
Weight: 55 lbs.
Price:$999
212
