Sumiko: Blue Point Special EVO III Moving Coil Cartridge
The evolution of the ever-popular Blue Point Special, the EVO III raises the performance bar even higher at this highly competitive price point. Its tonal balance is remarkably smooth, exhibiting a fundamental richness and overall warmth without sacrificing musical detail and resolution. Sound stage focus and channel separation are exemplary, as is the cartridges’ ability to maintain a coherent consistency that reproduces music as a perceptual whole.
High-output moving coil design with 2.5-mV output. Chemically coated aluminum cantilever with 0.3mm x 0.7mm elliptical stylus. Ultra low-resonance open generator design. Resonance controlled mounting system provides the lowest mechanical impedance. Highly compatible with most modern tonearms.
Cartridge Type: MC
Frequency Response:12Hz-50KHz
Output Voltage/Channel: 2.5mV
Channel Separation:35dB
Channel Balance: 0.5dB
Compliance:(x10-6 cm/dyne) 12
Stylus Size/Shape: .3x.7/Elliptical
Load Impedance: 47k Ohms
Tracking Force Range: 1.7-2.1 grams
Recommended Force: 2.0 grams
Cartridge Weight: 9.0 grams
Τιμή: £239 λίρες Αγγλιας
EUR 500.-στη Γερμανία
intergrale
