Super test: 37in LCD TVs
Κώστας Φ.
To αγγλικό AVReview φιλοξενεί συγκριτικό LCD τηλεοράσεων στις 37 ίντσες.
Εξετάζονται οι:
Acer AT3720
Price: £600
Size (on stand): 944(w) x 692(h) x 261(d)mm
Weight (inc stand): 24kg
Native aspect ratio: 16:9
Claimed max contrast ratio: 1200:1
Claimed max brightness: 450cd/m2
Connections: Two HDMI inputs, component video input, two Scarts (both RGB), composite video input, VGA PC input, stereo audio input, analogue tuner input, PC audio input
Hitachi 37LD8600
Price: £800
Size: 934(w) x 647(h) x 106(d)mm
Weight (inc stand): 27kg
Claimed max contrast ratio: 800:1
Claimed max brightness: 500cd/m2
Connections: One HDMI input, Two Scarts (1 RGB), Component video input, Composite video input, S-Video input, stereo audio inputs, RF input, PC D-Sub input, stereo audio output; Subwoofer line out; headphone jack
JVC LT-37DR7
Price: £1,000
Size: 800(w) x 591(h) x 244(d)mm
Weight (inc stand): 17.9kg
Connections: Two Scarts (both RGB); HDMI input; Component video input; S-Video input; Composite video input; Stereo audio inputs; Stereo audio output; RF jack; D-Sub PC port; Common interface slot; PC audio input; Headphone jack
LG 37LB1BD
Price: £1,000
Size: 1046(w) x 594(h) x 125(d)mm
Weight (inc stand): 30kg
Claimed max contrast ratio: 1600:1
Connections: 2 HDMI inputs, Component video input, Composite video input, Stereo audio inputs, Stereo audio output, Digital audio output, CAM slot, RF input, Three Scarts (one RGB, one DTV out), D-Sub PC input, PC audio input, Remote control jacks, RS-232C jack, S-Video input, remote control in/out
Philips 37PF9631D
Price: £1,300
Size: 991(w) x 707(h) x 114(d)mm
Weight (inc stand): 26kg
Claimed max contrast ratio: 7000:1
Claimed max brightness: 550cd/m2
Connections: Two HDMIs, component video input, electrical digital audio input, two Scarts, S-Video input, USB input, composite video input, stereo audio inputs, CAM slot for subscription TV channels, VGA PC input, PC audio input, RF jack
Samsung LE-37R74BD
Price: £1,000
Size: 991.5(w) x 713(h) x 326(d)mm
Weight (inc stand): 22.8kg
Claimed max contrast ratio: 5000:1
Connections: HDMI input, component video input, S-Video input, composite video input, stereo audio inputs, PC input, headphone jack, two Scarts (one RGB), tuner input
Sharp LC-37GD8E
Price: £850
Size: 926(w) x 644(h) x 120(d)mm
Weight (inc stand): 23kg
Connections: Two Scarts (both RGB), HDMI input, VGA/component video input; S-Video input; composite video input; stereo audio inputs; headphone socket
Toshiba 37WLT68
Price: £1,200
Size: 916(w) x 676(h) x 298(d)mm
Weight (inc stand): 24.4kg
Claimed max contrast ratio: 3500:1
Connections: Three HDMI inputs, component video input, two Scarts (one RGB), composite video input, VGA PC input, stereo audio input, digital tuner input, PC audio input, subwoofer line out, CAM slot, digital audio output
Τον τίτλο της καλύτερης TV του συγκριτικού κέρδισε η Philips 37PF9631D. Αντιγράφω απο το συμπέρασμα του AVReview:
"The weakest model we've featured has to be the Acer. This was probably inevitable given how amazingly cheap it is - and in fact it's by no means bad for something so affordable. But there's just no getting around the fact that its pictures are simply the least able in this group test.
You're pretty much looking at a tie for the 5th/6th/7th spots, between the Hitachi, JVC and Sharp models. While each of these models has one or two really standout qualities, they also each have a specific glitch or two sufficiently severe to force you to think twice before parting with your hard-earned cash.
It's similarly difficult to decide between the Samsung, Toshiba and LG models for our 2nd, 3rd and 4th spots. If you really pushed us we'd probably just about put the Samsung in 4th largely on account of it only having a single HDMI, the Toshiba in third since although it has three HDMIs its black levels are a touch disappointing; and the LG in second for its fine balance of good connectivity, good HD pictures, and aggressive price.
Tough though it may be to pick between some of our sets though, there can be no doubt about our overall group test winner - the Philips 37PF9641D. Yes, we know this is the most expensive set we've featured. But in terms of features and, above all, performance, it's in a class of its own, making it worth every solitary penny."
Περισσότερα εδώ.
koskef
