Synergistic Research νέα κόλπα… (HFT & FEQ)
deleted user 10898
Σας έχω και review (από Audiostream δηλ. Stereophile ουσιαστικά…)
http://www.audiostream.com/content/...-frequency-transducer-and-frequency-equalizer
More Than Just A Tweak
Over the years I have tried and owned countless products that have claimed to improve the sound of an audio system. But I have never heard anything that was as effective in elevating the performance of a high end system as the combination of the Synergistic Research High Frequency Transducer and the Frequency Equalizer. Soundstage, noise floor, bass detail and dynamic power, midrange and high end clarity all improve with the use of these products. I feel that both the High Frequency Transducers and the Frequency Equalizer should be used in combination as together they offer far more in performance than when either is used alone.
I know that some of you will be wondering where is the technical explanation of how the HFT and FEQ achieve these startling sonic results. I don’t have that information nor was it provided to me. I do know that the HFT and FEQ do what Synergistic Research claims that they will do in my system. So there is no baseless marketing hype here. As far as I'm concerned, these products live up to Synergistic Research’s claims and advertising.
The Synergistic Research High Frequency Transducer and Frequency Equalizer will become a permanent part of my audio system. Removing these components is simply unthinkable given the quality of the sonic enhancement achieved with their us
deleted user 10898
Ted Denney Lead Designer, Synergistic Research Inc.
HFTs are high frequency transducers as is clearly stated in the name of the product, while the FEQ acts as a low frequency RF dither in a listening room or space. That this explanation may not suit some is not my concern. Seventeen years ago I developed what would become the world's first commercially successful AC Power Cord that went on to sell over 10,000 units during the AC Master Coupler's 14 year production run. That power cords play a major role in the performance of high end systems is now obvious to most audiophiles. And despite a mountain of empirical evidence suggesting power cords effect the subjective performance of audio systems, they remain a stumbling block for some. No level of explanation can persuade people who refuse to listen to their systems.
As a designer of audio products I do my best to concisely explain what my products do and how they sound when used in an audio system. I then leave it to the end user to decide for themselves whether or not my products are right for them. To this end all Synergistic Research products are available for inhome audition with a money back gaurantee if not satisfied.
και…
HFTs are transducers that also act as resonators. How they perform as both transducer and resonator are directly related to how HFTs are manufactured which is a trade secret, at least until the patents are granted. For anyone wanting to try HFTs and FEQs in their system we offer a no risk 30-day trial period; more than enough time to determine wheather or not these new devices deliver the benefits we claim.
o πεφωτισμένος ted ότι σαχνει δεινει ρεσιτάλ εμπνευσης
το πρωτο είναι στο lab φιλου προς κοπιοποιηση
( με ένα καταλληλο κονδυλι και ένα τορνακι αντιγραφεται ευκολα.)
Βασιζεται σε προιοντα που κανουν συγκεκριμενη διαχυση , βεβαια αυτά κολιουνται και πανω στα ηχεια σε διαφορα μερη,όπως και στο ταβανι.
Το δευτερο πρεπει να ανοιχτει για να αντιγραφει.
Πλεον υπαρχει ακομα ένα προιον,
το οποιο πιθανο να είναι βελτιωμενη κοπια των <φιλτρων> της walker audio , προιον που εχω αντιγραψει εδώ και 5 συναπτα ετη.
Μετα την ευγενικη χορηγια προς εκτιμιση του εδώ αντιπροσωπου, και μιλαω για αυτα
http://walkeraudio.com/?product=high-definition-links
Τα νεα synergistic είναι αυτα
http://www.synergisticresearch.com/featured/new-product-release-xot-crossover-transducer/
Synergistic Research feels that the FEQ acts as a Tranquility Base for the room enhancing the total sound of your system.
The HFT measures a mere 8 mm in diameter and 8 mm in length. Using a little Blu Tack at the end of the HFT allows it to be attached to a wall, cables, etc. These devices are passive and require no active power supply. The HFT are sold in packages of 5 for $299 or $75 individually.
deleted user 10898
οπότε κύριε Ζίζικ, μάλλον έχετε την απορία, πως 5 "κόνοι" 8 χιλιοστών κάνουν "συγκεκριμένη διάχυση".
ορίστε….
A new answer. HFTs are tiny high frequency transducers that clean up high frequency harmonics in your listening room. You see, harmonics are interconnected, so when you affect harmonics -even those beyond the limits of human hearing – you also affect the lower frequency harmonics you can hear. HFTs literally cancel harmonic noise on any surface they are placed. And as you follow our easy placement guidelines, 5 HFTs at a time, you systematically overcome your room’s tendency to fight with your system. HFTs replace random out-of-tune resonance with sympathetic resonance that complements the music. Just 5 HFTs can affect a meaningful improvement to the average listening room, while additional HFT 5-pacs improve your listening enjoyment further until you ultimately bring your entire listening room in sync with the music.
συντομα θα είναι στα χερια μου οι κοπιες
αν δουλεψουν θα βαλω παντου,-θα δανεισω προς εκτιμηση.
Αν δεν,
θα εχω χασει 30 ευρω..................
Όπως, υποθέτω, και κάθε αντικείμενο στο χώρο. Ιδίως μεταλλικό;
deleted user 10898
αυτο με το μέταλλο με προβλημάτισε και εμένα…
είναι άραγε θέμα υλικών ή σχεδιασμού?
ο argy που τα αντιγράφει θα μας πει…
Είναι άραγε θέμα υλικών ή σχεδιασμού,ποιο πράγμα;
Πάντως όπως θα μας που και οι ειδικοί του φόρουμ φαντάζομαι,αυτά τα πραγματάκια λόγω της σκληρότητας του μετάλλου και του σχήματος,θα προσφέρουν κάποιο τυχαίο scattering.
Όπως και οτιδήποτε άλλο βάλουμε σε έναν χώρο.
deleted user 10898
8mm (χιλιοστά) χ 8μμ (χιλιοστά) scattering?
roberto_portale
