TECHNOMATE 6900HD COMBO
Πωλείται ο δημοφιλής δέκτης της Technomate ο οποίος πατσάρεται και παίρνει κλειδιά με USB stick. Πιάνει και τα ψηφιακά της ΕΡΤ. Είναι σε άριστη κατάσταση με απόδειξη αγοράς 18/4/08 και έχει εγγύηση μέχρι 18/4/09 (έχω και την κάρτα εγγύησης σφραγισμένη).
Κάθε έλεγχος δεκτός.
230€ (μαζί με hdmi καλώδιο)
TM-6900 HD COMBO
» High Definition Satellite & High Definition Terrestrial + 10,000 Channels + USB 2.0 with: PVR Ready for Timeshift, Record & Playback of Channels, Music/JPEG & Software Download + 1 Card Reader + 2 Common Interface (2CI) + HDMI & Component with Upscaler +
Specification
  • 2 High Definition Tuners: DVB-S/DVB-S2 Satellite & DVB-T Terrestrial Compliant (MPEG-2 / MPEG-4 / H.264)
  • Modulation: COFDM 64-QAM FEC Code rate 3-4 guard interval 1.16 8k carries
  • Output Resolution: 576p & 576i, 720p & 1080i
  • 1 Smart Card Reader & 2 Common Interfaces (2CI)
  • HDMI & Component Output (YPbPr) with Upscaler to Improve Picture Quality
  • 10,000 TV & Radio Channels
  • USB2.0 PVR Ready via external HDD or USB Flash Drive (memory stick) with Timeshift, Record & Playback functions
  • Music player and JPEG viewer via external HDD or USB Flash Drive (memory stick)
  • Software & Channel List download via USB 2.0
  • Fully Featured VFD text Front Panel Display
  • Sensitive Tuner
  • Less than 1 second channel change
  • Dolby Digital Optical S/PDIF
  • DiSEqC 1.0, 1.1, 1.2 & 1.3 (USALS) compatible
  • Auto Navigation system – select as many satellites as you want to search
  • On-screen display with true full color resolution
  • Enhanced 16 Favorite channel groups
  • Channel control by: Favorites, Lock, Skip, Move & Delete
  • Channel sort by: All, Alphabet, Transponder & CAS
  • Multilingual OSD Menu: English, Spanish, Portuguese, French, Dutch, German, Italian, Turkish, Arabic, Russian, Persian
  • Extended EPG and program reservation on EPG
  • Teletext & Subtitle by OSD and VBI
  • Last channel memory function
  • Factory default channel list
  • Various games
  • Software & channel list upgrade via RS-232C: PC to STB, STB to PC, STB-STB and USB
  • Parental, Installation & Receiver Lock
  • Zoom function on Pause & Live channel
  • Multipicture display
  • Support for multiple language broadcasts
  • SCPC & MCPC receivable from C/Ku band satellites LNBs supported: Universal, Single, Single S & C band wideband LNBs
  • Multi TV Standards supported: PAL G, I, K, M
  • 4:3 & 16:9 Screen Formats
  • 90-250V AC 50/60 Hz
  • LNB Short Circuit protection onboard
  • 2 Scarts & S-Video
  • Dimension 390X272X70 MM
Paul Skylodimos
