Thiel Audio CS3.7 Loudspeakers
Κώστας Φ.
Thiel Audio is finally starting to deliver their long-awaited CS3.7 loudspeakers ($9900 per pair). Enjoy the Music.com first announced way back in October 2006 during our Rocky Mountain Audio Fest coverage. Thiel's award winning CS3.7 floorstanding loudspeaker was named as an International Consumer Electronics Show Innovations Design and Engineering Awards Honoree for 2007. This 3-way, floor standing loudspeaker utilizes all newly developed drivers. A very high output 1-inch tweeter is coincidently mounted in the center of a 5-inch midrange that incorporates a new ribbed diaphragm geometry. The 10-inch woofer diaphragm geometry increases strength while lowering overall mass for wider bandwidth and higher efficiency. The output of the active woofer is augmented by an auxiliary bass radiator. Complete phase and time coherence output, high sensitivity (90dB/W/m), and low diffraction cabinet design are just a few of the design highlights.
enjoythemusic.com
Κώστας Φ.
Απάντηση: Thiel Audio CS3.7 Loudspeakers
Αναλυτικές πληροφορίες: Σελίδα Κατασκευαστή
CS3.7 specifications
Woofer: 10” with wave-shaped aluminum diaphragm, 3” diameter voice coil, 5 lb magnet in a 13 lb structure, copper pole ring, copper pole sleeve, short coil/ long gap design with 14 mm Xmax, die-cast chassis
Midrange: 4.5” with wave-shaped aluminum diaphragm, 3” diameter voice coil, 115 g (4 oz) neodymium magnet, copper pole sleeve, short coil/ long gap design with 6 mm Xmax, die-cast chassis
Tweeter: 1” aluminum dome, 64 g (2.3 oz) neodymium magnets, copper pole sleeve, short coil/ log gap design with 3 mm Xmax, coincidently mounted with midrange
Passive Bass Diaphragm: 10” wave-shaped diaphragm
Bandwidth (-3 dB): 32 Hz - 35 kHz
Frequency response: 33 Hz - 26 kHz ±2 dB
Phase response: minimum ± 10°
Sensitivity (2.8v - 1m, true anechoic): 90 dB
Impedance: 4 ohm (2.8 ohm min)
Recommended power: 100 - 600 watts
Size (w x d x h): 12.5 x 21 x 45 in /32 x 53 x 114 cm
Weight: 91 lb 41.5 kg
giannis9494
