Thor Audio
TA-3000 Phono Preamp
TA-3000 Specifications
Product improvements and refinements may be made without notice.
Retail Price $8490. USD (add $300. for gold accents)
TA-3000 Options add $300. for 24 ct Gold accents
Chassis 14" Toroid with 8" external Power Supply
Cartridge Load (MM) Resistor 470k, 47k, 1k, 100 Ohms
Capacitor 270pf, 180pf, 150pf, 100pf
Cartridge Load (MC) Autoload
Total Outputs Main (1)
Output Impedance 400 Ohms
Total Harmonic Distortion .01%
Frequency Response 15-35kHz ± .1dB
Phono Frequency Response 20-20kHz ±.1dB RIAA Curve
S/N -84.2 dB
Gain 60 dB (MC), 40dB (MM)
Tube Complement 12AX7 (4), 12AT7 (2)
TA-1000 Control/Line Preamp
The TA-1000's External Power Supply and Remote Control
TA-1000 Specifications
Retail Price $9990. USD - Includes Remote Control
TA-1000 Options 24 ct Gold accents (add $400.)
Options:
Home Theater By-Pass Switch, Rec/Buffered Line Out for Tape/Dat (replaces Dual Outputs), or discrete resistor/Stepped Attenuator (replaces the Remote Control)
These options are no extra charge when ordering new components.
Total Inputs (4) CD, Tuner, Tape, Aux
Input Impedance 250 K
Total Outputs Main Outs (2) (Dual Outputs Standard)
Optional Rec/Buffered Line Out for Tape/Dat (no charge for new components)
S/N -85.4 dB/Line
Gain 20dB
Tube Complement 12AX7 (2), 12AT7 (2)
TPA-150 Mono Block Amplifier
TPA-150 Specifications
Retail Price $24,990. USD (pair) (add $1000. for gold accents)
Chassis 20" Round
Output 150 Watts 4/8 Ohms (ultra-linear)
Input Sensitivity 1.2 Volts RMS + 2% for 150 Watts into 4/8 Ohms
Input Impedance 100 K
Input Connectors Single-ended, non-inverting RCA jack or Pseudo-balanced, non-inverting 3-pin XLR connector
Tube Complement 12AT7 (1), 12AU7 (1), 12BH7 (1), EL34 (8-Svetlana)
Frequency Response 10Hz - 60KHz ± .1 dB
TPA-60 Mono Block Amplifier
TPA-60 Specifications
Retail Price $17,490. USD (pair) (add $750. for gold accents)
Chassis 16" Round
Output 60 Watts into 4/8 Ohms (ultra-linear)
Input Sensitivity 1.2 Volts RMS + 2% for 60 Watts into 4/8 Ohms
Tube Complement 12AT7 (1), 12AU7 (1), 12BH7A (1), EL34 (4-Svetlana)
Frequency Response 10Hz - 60KHz ±.1 db
REVIEWS:
http://www.stereotimes.com/amp010405.shtm
http://www.tnt-audio.com/ampli/ta1000e.html
Nikos88
