THX Theater Basics 101
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Room and Layout
  • Geometry that allows for a good image size, seating locations and reasonable distribution of room modes
  • Controllable lighting system
  • Decor that doesn't reduce image contrast or negatively affect color perception
  • Seating away from the side and rear walls to prevent negative acoustical interactions
  • Field of view for 16:9 image that's between 36 and 52 degrees, assuming multiple rows of seats
Environment
  • Background noise less than NC-20 (that's ultra quiet) with all mechanical and presentation systems operational
  • Control of room acoustics so reflections are inaudible
  • Sufficient sound isolation, also below NC-20
Equipment
  • Projection system with acoustically transparent screen
  • Front speakers placement behind the screen
  • THX-certified or approved equipment with sufficient output for the room size
  • Four subwoofers minimum, at locations that provide uniform bass response
  • Four surround channels minimum, for 7.1 capability
  • Automation or simple-to-use remote
http://www.cepro.com/article/thx_theater_basics_101/K5
DimAster
