Tomb Raider Anniversary Nude Patch (PC)
The Tomb Raider Anniversary Nude Patch will change Lara Croft's outfit into .. well, nothing. Combined with the stunning graphics of Tomb Raider Anniversary this is sure to give you an unique view. Update: Nude patch version 1.7 is now available for download as well.
TRA Nude Patch Download
TRA Nude Patch Installation
  • Start Texmod.exe
  • Make sure you are in the Package Mode
  • Click in the Target Application the Browse button and select the path to your tra.exe file
  • In the Select Packages part there is a small Browse button to the right, click that
  • Select the file tra_neonude.tpf
  • A package TRA_NEONUDE should appear on the left side
  • Click on that name
  • Click the Run button
  • In the game, you must select Replay Level and select from the outfits Wetsuit
  • Click Start game and enjoy the view :)
Πηγή: http://tomb-raider-anniversary.com
Σελίδα: http://tomb-raider-anniversary.com/tomb-raider-anniversary-cheats/nude_patch/
:happy_4: :happy_4: :happy_4: :happy_8: :happy_8: :happy_8:
Απάντηση: Tomb Raider Anniversary Nude Patch (PC)
Μην περιμένετε τίποτε γραφικά επιπέδου αλλά θα έχει πλάκα φαντάζομαι....."happy_1"
Αν κάποια φωτό (ή κάποιες) είναι "λάθος" μην διστάσετε να την διαγράψετε!! :happy_4::cool_4::cool_4:
Lino
