Topfield TF7710 HD PVR - Παρουσίαση
Features
* Fully DVB-S / DVB-S2 (H.264) HD compliant
* With 2 tuners
* Time shift supported
* Dual Recording supported
* XviD codec embedded
* USB memory supported
* 5000 TV & radio services programmable
* Multilingual audio support
* Multilingual menu text support
* Favorite service list editing
* Electronic Program Guide (EPG) for on screen service information
* Subtitle supported
* Parental lock facility by service and program event
* Firmware update via LAN port
Specification
Transport Stream A/V Decoding
Aspect Ratio 4:3, 16:9
Video Resolution 576i, 576p, 720p,1080i
A/V & Data In/Out
TV Scart Video CVBS/RGB/YUV output, Audio L/R output
VCR-Scart Video CVBS output, Audio L/R output
Video CVBS output, Audio L/R input for bypass
RCA A/V Video CVBS output
Audio L/R output
HDMI HD Video/Audio Output
Component YPbPr output
S-VIDEO Video S-VIDEO output
S/PDIF Digital audio or Dolby AC3 bitstream output
LAN 10/100 Mbps Ethernet
RS-232C 9 pin D-sub type
Transfer rate : max. 115.2Kbps
Front Panel
Keys 5 Keys(VOL -/+, STANDBY, CH -/+)
USB USB 2.0 Host
RCU 48 Keys
Power Supply
Input Voltage 95 250 VAC, 50/60Hz
Type SMPS
Power Consumption Running: Max. 60W, Standby: 9W
Physical Specifications
Size(WxHxD) 430 x 60 x 265 mm
Weight(Net) 3.8 kg
http://www.topfield.co.kr/
opanamas
