UL SOUND από τη Νότια Κορέα
power amplifiers
NOBLE 826
AMAZE EL34
AB1 CLASS 35 W
pre amplifier / phono eq
AMAZE
AMAZE PRE AMPLIFIER SPECIFICATIONS
◇ Frequency response---------- 20Hz ∼ 50Hz +/- 0.4dB
◇ Phono RIAA Accuracy--------- Within +/- 0.4dB, 20Hz ∼ 20kHz
◇ Total Harmonic Distortion--- 0.06%
◇ HUM & NOISE----------------- 0.000035v
◇ Maximum Output-------------- 10V before clipping
◇ PRI OUT Impedance----------- 600Ω
◇ Input Impedence------------- Phono 47Kohm
◇ Input Sensitivity----------- Phono 1mV, High level 120mV
◇ Maximum Input--------------- Phono 80mV at 1kHz, High level 3.5V at 1kHz
◇ Signal-to Noise Ratio------- High Level 100dB(A weighted), Phono 86dB, ref.5mV(A weighted)
◇ Dimensions------------------ 380 wide ×110 "high 280" deep
◇ Weight---------------------- 16kg
power amplifiers
NOBLE 826
AMAZE EL34
AB1 CLASS 35 W
AMAZE
