ULTRASONE Signature STUDIO
Ultra Audio
Σφραγισμένα στο κουτί τους τα κορυφαία ακουστικά ULTRASONE Signature STUDIO
Handmade in Germany !
Τιμή προσφοράς 375 ευρώ, μετρητοίς ή έως 12 Άτοκες Δόσεις με πιστωτική κάρτα.
Δωρεάν αποστολή / αντικαταβολή παντού.
Υπάρχει και δυνατότητα ακρόασης σε ζεύγος επίδειξης!
Περιορισμένα σφραγισμένα τεμάχια.
TITANIUM AT ITS HEART: THE SOUND TRANSDUCER
At the heart of the Signature STUDIO are titanium-coated 40-millimetre Mylar sound transducers. This is the perfect diameter to ensure reliable sound assessment is possible. With a frequency range of 8 to 40000 Hz, the Signature STUDIO covers a spectrum larger than the range of human hearing. The coating with one of the hardest materials in the world guarantees high-resolution and precise reproduction of the audio material.
ROBUST DESIGN FOR PROFESSIONAL USE
The ULTRASONE Signature STUDIO exudes professional elegance. The no-nonsense, robust PRO design is made for tough daily use in the recording studio or on the go. Simply put: the Signature STUDIO was designed for demanding use. That means we use the same robust plastic from the PRO series, with its tried and tested durability, for the headband and ear cups. The same criteria were used when choosing the material for the head and ear pads.
Along with S-Logic® Plus technology – which makes near fatigue-free sound assessment possible for hours at a time – the combination of the Signature STUDIO’s comfortable cushioning and its light weight of only 290 grams ensures comfortable extended use. The headphones adapt automatically to the wearer’s physiognomy. Breathable materials prevent irritating transpiration under the ear cups. This allows you to focus on the nitty-gritty: the music.
TECHNICAL DATA
  • Principle: dynamic, closed
  • S-Logic® Plus technology
  • MU-metall shielding – ULE technology
  • Impedance: 32 ohms
  • Driver/Size: Mylar/Titan, 40 mm
  • Magnet: NdFeB
  • Frequency range: 8 – 40.000 Hz
  • SPL: 98 dB
  • Weight (excl. cable): 290 g
  • Handmade in Germany
πληροφορίες στο τηλ. 210 3839399
Ultra Audio
Το σφραγισμένο επωληθη.
Διατίθεται ένα τελευταίο με ανοιχτή συσκευασία (B-stock) λόγω 10λεπτης επίδειξης, μόνον με 329 ευρώ!
Δωρεάν αντικαταβολή-αποστολή παντού.
Πληροφορίες με π.μ. ή στο 2103839399
Made in Germany
Ultra Audio
Επωλήθη εκτός.
Παρακαλώ να κλείσει η αγγελία.
Ευχαριστούμε για την φιλοξενία.
Klipschlascala_pro1988
