Venus / Raymond weil / Victorinox
Venus Swiss made gold watch
Waterproof: 30m Case Material: Stainless steel Strap material: Stainless steel Display: Analogue Glass: Mineral glass Case color: Gold Dimension: Small (20mm-35mm) Dial color: Black Guarantee: 2 year official guarantee Strap type: Bracelet Clasp type: Fold-over Deployment Strap color: Gold Movement: Quartz Movement type: Swiss made Diameter: 25mm Thickness: 5.00mm
120€
RAYMOND WEIL 18KT AND STEEL PARSIFAL
Movement: Swiss Quartz Analog ETA ( Battery powered ).
Functions: Date calendar, window display.
Case: Combination satin/polished finish.
Bezel: 18kt solid Gold. Fixed position (stationary).
Crown: Cabochon stone set.
Crystal: Flat profile. Sapphire.
Dial: White color. Applied polished Yellow color markers.
Hands: Yellow color. Tritium luminous filled.
Case Back: Screw-on style ( held by screws ). Factory Engraved/Raised Logo.
Band: Combination satin/polished finish. Solid Stainless steel and 18kt Gold combination.
Clasp: Butterfly style
Water Resistance: 30m/99ft/3atm.
Case Size: 35.00mm. 06.00mm.
Production date circa 1990's.
350€
Victorinox swiss army
Mans watch brand new and never worn.
Top class stainless steel construction.
Waterproof to 100 metres.
Always displays two choosable time zones
Sapphire Crystal lens.
39mm dial. Quartz movement.
Beautiful quality smooth rounded finish with the Quality you would expect from VICTORINOX.
Still has tags attaches, and stainless steel padded case.
120€
Και τα 3 ρολογια χρειαζονται μπαταρια. Η νεα μπαταρια θα μπει μπροστα στον αγοραστη,για τον ελεγχο καλης λειτουργιας.
Συσκευασιες και χαρτια δεν υπαρχουν.
Μια καλη μειωση σε ολα,ειδικα στο RAYMOND WEIL οπου αυτη την στιγμη πωλειται στα 1400€ καινουργιο.
80€
250€ (
μπηκε και νεα μπαταρια)
80€
flastex
