Viewsonic Pro8200 1080p Home Theater Projector
[imgl]http://www.projectorcentral.com/img.cfm?pid=5996[/imgl]Good home theater doesn't have to cost much. The Viewsonic Pro8200 is a 1080p projector that costs less than $1,000 from authorized resellers. Its 2,000 lumen maximum brightness makes it quite versatile, able to project in the theater or the living room equally well. A 1.5:1 manual zoom lens allows easy placement in many rooms, while a pair of HDMI ports and dual 10W speakers create opportunities to use the Pro8200 as a mobile theater in itself, free of fixed installations and A/V receivers. Low-cost replacement lamps, a 6,000 hour maximum lamp life, and a three-year warranty ensure affordability. The Pro8200, while easy on the budget, is a capable home theater projector suitable for theater/film viewing or Sunday afternoon football.
Source: projectorcentral.com
clubgr
