visaton bgs 40 8 ohm (15'')--b200 faceplug 6ohm (8")
bgs 40 8ohm 100€
b-200 faceplug 100€
κατασταση αριστη
τηλ 697.47.76.799 Δημητρης
θα ανεβουν και φωτο
8'' fullrange 6 ohm
15'' woofer 8 ohm
απο απο σχεδιο visaton open bafle (www.visaton.com)
αλλες εφαρμογες
Open Baffle Subwoofer – OBH1 ASYMMETRIC (ring audio)
Asymmetrical design of the open baffle in the form of the “H” with asymmetrical sides of the frame does not cause resonance of the room, while the lack of the cabinet gives it another important advantage in comparison with classical subwoofers: easier placement and synergy with electrostatics and highly sensitive speakers which have very light membranes - for this reason they do not tolerate pressures of classical subs with slow impulse response. OBH1 has an amplifier with high damping factor and it can perfectly control the driver as well as, if needed, upraise the response of the subwoofer for a natural fall of 12 dB (which used to be one of the main reasons for abandonment of this work principle). Due to mathematical models and simulations available today and after deliberation and listening, a driver capable of completing the job with exceptional control and plausibility has been chosen.
Driver: Visaton BGS-40
Amplifier: Internal amplifier with digital crossover – Hypex DS 1.2, power output 120 Wrms into 4 Ohms.
Frequency response: 28 Hz-150 Hz
Internal wiring - Ring Audio
Dimensions in cm: H70 x Wh40 x Wl55 x D80
b200 8 ohm
πολλες εφαρμογες στην σελιδα της visaton και παρα πολες στο διαδυκτιο
omega aperiodic 8
http://www.6moons.com/audioreviews/redwine3/system.html
6974776799
kriono
