Vivid Audio D2 Series Loudspeakers
Κώστας Φ.
Ή αλλιώς: Take me to your leader :cool_11:
D2-AL-1 £3600 - pair of speakers shown in aluminium, centre left of image.
D2-ISO-5 £6200 - pair of speakers shown in aluminium, bottom centre of image
D2-ISO-5XCT £10,000 - speaker shown in aluminium, large image.
Customised options: showing the D2-AC in black lacquered high gloss finish, centre right of image, extra £250.
D2-AL-1 Series
  • Principle: 3 ways
  • Power Handling (Watts RMS) 130
  • Frequency (Hz) 40Hz-20kHz
  • Z-Nominal Impendence (Ohms) 8
  • Sensitivity (dB/1 Watt@1m) 86
  • Crossover points 3.5kHz
  • Dimensions (H mm, diameter mm) 928 x 373mm
  • Cabinet Volume (litre) :Tweeter 0.06, Mid range/Bass 15
  • Wiring Option - Bi-wired/ Bi-amped
  • Weight (kg per speaker) 11
D2-ISO-5 Series
  • Principle: 3 ways
  • Power Handling (Watts RMS) 150
  • Frequency (Hz) 30Hz-20kHz
  • Sensitivity (dB/1 Watt@1m) 89
  • Crossover points 250Hz, 3.5kHz
  • Cabinet Volume (litre) Tweeter 0.06, Mid range 5
  • Bass 10(a)/20(e)
  • Weight (kg per speaker) 16
D2-ISO-5XCT Series
  • Principle: 3 ways
  • Sensitivity (dB/1 Watt@1m) 88
  • Dimensions (H mm, diameter mm) 1062 x 542mm
  • Bass 10(a)/20(e)
  • Weight (kg per speaker) 33
Aluminium alloy grade 3003A, EVA/Bitumous composite (D2 Series)
· The tweeter housing is machined from solid aluminium, with an extruded aluminium support (D2-ISO5)
· The D2 body is mounted on O-rings onto the spun aluminium crossover enclosure via three breather tubes. (D2-ISO-5XS)
Tweeter soft dome 28 mm double Neodymium magnet with Hexatech aluminium voice coil
· Mid range unit: polypropylene cone, double hybrid magnet system, steel chassis, two units wired out of phase
· Bass units: double magnet Hexatech aluminium voice coil, rigid steel basket (D2-AL-1); twin 215mm polypropylene cone drive units mounted face to face in a constant pressure arrangement (isobaric), 50mm voice coil, rigid cast chassis (D2- ISO-5XCT, 5XS)
Πηγή: hi-techliving.com
giannis9494
