Vivitek H9080FD 1080p LED DLP Projector
[imgl]http://www.projectorcentral.com/img.cfm?pid=4976[/imgl]The Vivitek H9080FD is revolutionary. It is more than just an LED projector - it is a serious home theater product that just happens to use LEDs for illumination. The distinction is fine, but important. This is not a gimmick product, nor is it merely a proof-of-concept. It is a projector that many of us would be proud to use in our own theaters. It has the best ANSI contrast we've yet seen, a broad color gamut, great saturation, a razor-sharp picture, and some nice ease-of-use features like lens shift - which, even while it is hard to adjust, has an overall range which exceeds that of most competitive 1080p DLP projectors.
Source: projectorcentral.com
Απάντηση: Vivitek H9080FD 1080p LED DLP Projector
Που είναι ρε παιδιά;. Γιατί δεν σχολιάζει; Πάλι Blu-Ray γράφει; :135:
"Where this projector really shines, though, is ANSI contrast. ANSI contrast describes the relative black and white levels that can appear in the same image at the same time - in other words, ANSI contrast measures the maximum contrast in any one particular image. In the past, the best projectors we've seen measured around 580:1 or 600:1, while many very good projectors measured 450:1 or lower. This background information is provided in order to put the following number in perspective: the Vivitek H9080FD measured 844:1 ANSI contrast in our test lab. This is nearly half again as much as the next nearest competitor, and very impressive by any reasonable standard. The dynamic range on screen at any given time is broad enough to do justice to even the highest-contrast content available".
the Vivitek H9080FD measured 844:1 ANSI contrast in our test lab. [/I]
εγω παλι δεν καταλαβαινω τιποτα.Με καμμια 400αρια λουμενς και μετρια μαυρα οταν παιζει(απ'οτι λενε γενικως)πως βγαζει τετοιο ΑΝΣΙ?Καλα για ον-οφ δεν μιλαμε γιατι σβηνουν(σχεδον) τα λεντακια και φαινεται οτι βγαζει πραγματικο μαυρο τοτε.(επιτελους παντως ενας ψηφιακος μπορει να βγαζει μαυρο!!!!)
Δείτε τα εντόσθια του!:126:
kkoumas
