Volumio Primo
m1ts0s
News poster
FEATURES
  • Uncompromised Bit-Perfect Audio Playback
  • Hi Quality Audio Output powered by ESS SABRE 9028QM DAC
  • USB Audio Output up to PCM 32 bit 768 kHz and DSD512
  • SPDIF Audio Output up to 24 bit 192 kHZ
  • Supported Formats: DSD, WAV, FLAC, Alac, Aac, Vorbis, Cue, Mp3 and more
  • Playback control and configuration via Web-app from anything with a browser
  • Powered by ASUS Tinkerboard S
  • HDMI Video Output
  • UPNP \ DLNA Renderer with Open Home support
  • Integrated WebRadio directories
  • CIFS\SMB and NFS Network Attached Storage compatibility
  • Multilanguage
  • Alarm and sleep function
  • Wireless and Wired Network Connectivity
VERSATILE OUTPUT OPTIONS
Volumio primo integrates an excellent ES9028Q2M D\A Converter which outputs a superb Analog signal via a pair of high-quality gold-plated RCA connectors. But, should you prefer a pure digital output Primo features also a coaxial S\PDIF out. Not to mention that you can also connect an external DAC via one of 4 USB ports, capable to stream glitch-free audio up to 32 bits and 768 kHZ and DSD 512.
Cherry on the cake is its HDMI output: this way you will be able to enjoy Volumio’s user interface directly from Primo. For example on your Living Room TV or a desktop touchscreen.
PLAY ANY DIGITAL MATERIAL YOU WANT
As Volumio, Primo is a universal player: from mp3s to Hi-Resolution flacs, Internet Radios, DSD files and of course Hi-Res Music Streaming services like TIDAL and Qobuz.
If that wasn’t enough, Volumio’s plugins store offer a variety of other third party integrations like Spotify, YouTube, TuneIn Radio and much more.
POWERED BY ASUS
We wanted our streamer to have the best possible Computer hardware: that’s why we designed the Primo around the excellent ASUS Tinkerboard S. Unlike similar solutions (Raspberry PI) Tinkerboard has a carefully designed USB bus and clock, which makes it ideal for audio applications. Furthermore it has a very powerful processor, which results in smooth operations even on the most demanding tasks.
Last, it features an integrated 16GB Solid State memory which is more stable and faster compared to SD Card storage.
FIRST-CLASS NETWORKING
Being Primo a network music player, its networking capabilities must be up to the task. And they do: Gigabit Ethernet for ultra-fast transfer speed and an external Wi-Fi antenna for optimal signal.
TECHNICAL SPECIFICATIONS
Analog output: ES9028Q2M DAC via I2S, PCM 24 bits 192kHz , DSD128 via DoP
S\PDIF output: PCM 24 bits 192kHz
USB output: 4X USB 2.0 , PCM 32 bits 768kHz
CPU: Quad core 1.8 GHz ARM Cortex-A17 with passive heatsink
RAM: 2GB
Internal Memory: 16GB Emmc
Video Output: HDMI, up to 4K resolution
LAN: Gigabit
Wireless Networking: 802.11 b/g/n Wi-Fi & Bluetooth 4.0 + EDR with External Antenna
Regular Price 399€
Pre-Order 349€
+ 1 Year MyVolumio Superstar Subscription (worth 67€)
+ Free Shipping
https://volumio.org/primo
dimoslecce
