Vu Meter Στο Αυτοκίνητό Μας!!!
Features
Remote temperature sensing (monitors amplifier temperature right from the dash!)
0 - 25VDC Voltage monitor
Stereo (left and Right) channel signal meters
High/Low level input (Built in line level converter)
The IF-4VU not only looks great but gives you all the information to keep your system running for years and years. This gauge system tells you the temperature of anything connected to the remote temperature sensor (amp, subwoofer, etc.). The voltage meter allows you to monitor your vehicles voltage. This is a major benefit to prolonging the life of your equipment. Now, you can also monitor your headunits output signal with the stereo level meters. The stereo level meters monitor the signal from any headunit (high or low level). This helps you monitor the stereo signal and avoid any clipping signals. Since this unit can take either low or high level inputs, it can be used with an aftermarket or factory car stereo. It's an installers dream come true.
wendigo
