Vu+ Zero Full HD 1080p
Τιμη : 130€
Vu+ Zero Features:
• Opera browser
• HbbTV
• HDMI 1.4 connection
• DVB-S2 tuner
• External 12 V power supply
Technical Highlights:
• 2K DMIPS processor
• DVB-S2 tuner
• 256MB Flash
• 512 MB DDR3 DRAM
• 1 x Smartcard-Reader (Xcrypt)
• 2 x USB
• 10/100 Mbit Ethernet Interface
• 1 x HDMI 1.4 video / audio output (digital)
• 1 x RCA video output (analog)
• 2 x Audio Output (L / R) RCA (analog)
• unlimited channel lists for TV / Radio
• EPG (electronic program guide) support
• Support of favorite lists (bouquets)
• OSD in many languages and skin-support
• expandable with plugins
• Automatic / manual channel search
• DiSEqC 1.0 / 1.1 / 1.2, USALS
• External 12V power supply
• Power switch
Vu+ Zero Specifications:
• DVB-S2 tuner:
• Input Frequency Range 950 ... 2150 MHz
• Input level range - 65 dBm ...- 25 dBm
• Tuner Input Connector F connector
• Input impedance 75 ohms
• AFC capture range +/- 3.5 MHz
• Demodulation Goldwafers.com QPSK and 8PSK
• Viterbi and Reed-Solomon FEC
• Viterbiraten 1/4, 1/3, 2/5, 1/2, 3/5, 2/3, 3/4, 4/5, 5/6, 8/9
• Roll-off Factor 35%
Video decoding:
• Video compression MPEG-2 / H.264 and MPEG-1 compatible
• Video Standard PAL G / 25 Hz, NTSC
• Aspect Ratio 4: 3/16: 9
• Letterbox for 4: 3 TV-Device
Analog output:
• Output Level L / R 0,5 Vss on 600 Ohm
• THD> 60 dB (1 kHz)
• Crosstalk <-65 dB
Video parameters:
• CVBS input level 1 Vpp +/- 0:25 dB at 75 Ohm
Ethernet:
• 100/10 MBit compatible interface
USB:
• USB 2.0 connection (2x)
LNB power and polarization DVB-S2 tuner:
• LNB Current 400mA max. Short-circuit protected
• LNB Voltage horizontal without load 19,5V17,6V at 400mA
• LNB Voltage vertical load without 14.5V 11.8V at 400mA
• LNB is switched off in standby mode
Control of the satellite position:
• DiSEqC 1.0 / 1.1 / 1.2 and USALS - Rotor Control
Power Consumption:
• <13W (in operation, with LNB)
• <12W (in operation, without LNB)
• <0.5W (Deep-Standby-Mode)
Input:
• External power supply:
• Entrance:
• 110-240V AC / 50-60Hz / 1,0A
• Exit:
• 12V = / 3,5A
General:
• Ambient temperature + 15 ° C ... + 35 ° C
• Humidity <80%
• Dimensions (W x D x H): 211 mm x 185 mm x 40 mm
Contents of Box:
• Satellite Receiver (Vu+ Zero)
• Remote control
• Batteries
• Cable for analog A / V outputs (3.5 mm jack)
• External IR sensor
• User manual
opanamas
