Κώστας Φ.
"Truly high performance machines are not for everyone. They have particular characteristics which set them apart, and as such they appeal to a select group of people. So it is with the Curve speakers, which are capable of thrills and excitement. They are taut, racy things which pound the acoustic pavement with sure-footedness. For their dimensions, they produce prodigious bass. They are not a detail-phile’s dream, but rather a sophisticated music lover’s object of desire, playable at obnoxious levels without a care for quiet. They are dark and swift, smooth and seductive. They have drop dead looks and never-say-die listenability. If this is what you’re looking for, you’ve found your super-speaker."
Full Review: Dagogo.com
Specifications:
Type: 2.5-way, true linear phase, free space, ported enclosure, floorstanding monitor
Drive Units: 1-inch Wilson Benesch soft dome ultra linear tweeter, hand painted silk;
7-inch Wilson Benesch Tactic bass/mid range unit
7-inch Wilson Benesch Tactic bass unit
Frequency Range: 32Hz ~ 30kHz (-6dB), 35Hz ~ 25kHz (-3dB)
Sensitivity: 88dB/m/w
Impedance: 6Ω nominal, 4Ω minimum
Crossover: First order bass roll-off, Second order mid range and tweeter crossover
Low Frequency Loading: Bessel alignment of fourth order reflex. Double chamber, differential tuning
Input Connections: Bi-wireable
Power Handling: 200W peak unclipped program
Internal Volume: 42.5 liters
Dimensions: 36" H x 9" W x 15" D
Net Weight:106lb
MSRP: $8,795/pair
