WMP , VLC , BSP και τωρα GOM
HV
Ενας πολλα υποσχομενος νεος σχετικα PLAYER ειναι ο GOM...
Δεν τον εχω δοκιμασει παρα πολυ αλλα εφοσον ειναι Freeware μπορειτε ολοι να δειξετε μια ματια στο site του..
http://www.gomplayer.com
GOM Player supports most popular codecs (AVI, DAT, MPEG, DivX plus many more) with its own embedded codec system that you won't have to look for appropriate codecs everytime you can't play a certain video format. For those codecs that require a license that cannot be distributed, GOM will automatically lead you to an open-source codec web-site.
Plays Broken FilesWatch video files while you are downloading them! GOM has a registered patent for playing broken AVI files and files that are still being downloaded. So try one of your broken AVI files or one that you are downloading right now. You'll find it amazing!
Enjoy Advanced FeaturesGOM supports a lot of advanced features for advanced users. You can customize the player by creating your own skin, setting toggle keys, VMR modes, detailed resolution among others. It also provides features such as an overlay mixer, real-time index rebuilding for AVI files, unicode support, key frame based RW/FF and many more!
roberto_portale
