XTZ Headphone Divine - The World’s First High-End DSP Wireless Headphone
m1ts0s
News poster
https://www.kickstarter.com/projects/1173793437/worlds-first-dsp-enabled-wireless-headphone
XTZ με Dirac:
Competitive advantages:
  • Cable-free with Bluetooth 4.0
  • Bluetooth interface: HSP, HFP, A2DP, AVRCP
  • If the battery is low, you can still use the headphones by connecting the by-pass cable
  • Up to 10 meters connection range
  • aptX® audio coding delivers CD-quality wirelessly over Bluetooth.
  • NFC pairing - just touch the devices
  • Optimized sound quality with DSP technology from Dirac
  • Light and convenient to carry
  • Strong construction to handle indoor and outdoor use
  • Works as a head-set with built-in microphone
  • 40mm Neodymium drivers
  • Output level 97dB / 1kHz
  • Frequency Response 15 – 32.000 Hz
  • Impedance @ 1kHz: 59 ohms
  • Multifunction key (volume, play, pause, answer)
  • Up to 14 hours of continuous play
  • Ear-cushion and headband cushion in Korean leatherette
  • Weight is 170 Grams, we have worked hard to reach a low weight, with long battery time and still have good rigid construction.
Function details:
  • International standard Micro USB cable
  • Shows On/Off Status
  • 3.5mm Passive Connection
  • Volume Control Up/Down
  • On/Off Switch
  • Microphone for phone-call and sound recording
Evasound
