http://www.xtz.se/product/sub-8-17
Driver: 8” High speed Driver
Frequency Response: 29 Hz - 160 Hz (Ported), 39 Hz - 160 Hz (Closed)(+/-3dB)
Variable low pass: 40 - 160 Hz
Crossover: 12 dB/Octave
Phase: 0 - 180 ° (Variable)
Amp Power: 200 Watt RMS, 350 Watt Peak Power
Inputs: L & R Unbalanced RCA, LFE Unbalanced RCA, High Level
Warranty (Speaker): Five Years
Warranty (Amplifier): Two Years
Dimensions: (HxWxD)335 x 260 x 360 mm
Weight: 13 kg
http://www.xtz.se/product/sub-10-17
Driver: 10” High speed Driver
Frequency Response (+/-3dB) : 20 Hz - 160 Hz (Ported), 26 Hz - 160 Hz (Closed)
Variable low pass: 40 - 160 Hz Crossover 24 dB/Octave
Phase: 0 - 180 ° (Variable)Amp Power 500 Watt RMS, 800 Watt Peak Power
Inputs: L & R Unbalanced RCA, LFE, Unbalanced RCA, Balanced XLR, Program Port
Warranty(Speaker): Five Years
Warranty(Amplifier): Two Years
Dimensions (HxWxD): 420 x 320 x 380 mm
Weight: 19,5 kg
http://www.xtz.se/product/sub-12-17
Driver: 12” High speed Driver
Frequency Response (+/-3dB): 19 Hz - 160 Hz (Ported), 25 Hz - 160 Hz (Closed)
Crossover: 24 dB/Octave
Amp Power: 500 Watt RMS, 800 Watt Peak Power
Inputs: L & R Unbalanced RCA, LFE Unbalanced RCA, Balanced XLR , Program Port
Dimensions(HxWxD): 500 x 395 x 400 mm
Weight: 25,9 kg
test
http://www.hdfever.fr/2016/01/26/test-xtz-10-17-et-12-17/
