Yamaha 5. RX-V1600 7.1-Channel Digital Home Theatre Receiver
Σε αριστη κατασταση αφού το home cinema τελικα δεν με κέρδισε ποτε / ειμαι του δικάναλου ηχου .
με το manual και τα τηλεκοντρολ του
SPECS
GENERAL
  • Type
    AV receiver
  • Available Body Colors
    black, titanium
  • Manufacturer
    Yamaha
DISPLAY
  • Display Type
    Fluorescent display
AUDIO
  • Response Bandwidth
    10 - 100000 Hz
  • Signal-To-Noise Ratio
    100 dB
  • Total Harmonic Distortion
    0.04 %
POWER DEVICE
  • Power Outlets
    2 AC outlets
  • Type
    power supply
AUDIO SYSTEM
  • Type
    AV receiver
  • Subcategory
    AV components
  • Functions
    AV receiver
  • Audio D/A Converter
    24bit / 192kHz
  • Built-in Decoders
    DTS 96/24, DTS Neo:6, DTS decoder, DTS-ES Discrete 6.1, DTS-ES Matrix 6.1, Dolby Digital, Dolby Digital Surround EX, Dolby Pro Logic, Dolby Pro Logic II, Dolby Pro Logic IIx
  • Surround Sound Effects
    Quad-Field CINEMA DSP, SILENT CINEMA DSP, Tri-Field CINEMA DSP, Virtual CINEMA DSP
  • Surround System Class
    7.1 channel
  • THX certified
    Yes
  • Digital Sound Processor (DSP)
    Yes
  • DSP Preset Qty
    19
  • Additional Features
    A/B/A+B speaker switch, Bi-Amplifying, Yamaha Parametric Room Acoustic Optimizer (YPAO), de-interlacing, gold plated connectors, multi-room audio output, on-screen display, source direct
  • Bass Control
    Yes
  • Treble Control
    Yes
  • Built-in Clock
    sleep timer
HEADER
  • Brand
    Yamaha
  • Product Line
    Yamaha
  • Model
    RX-V1600
  • Packaged Quantity
BUILT-IN DISPLAY
  • Type
    fluorescent
MISCELLANEOUS
  • Timer
    sleep
EQUALIZER
  • Equalizer
    Yes
  • Equalizer Type
    digital graphic
  • Equalizer Band Qty
    7 bands
AMPLIFIER
  • Output Power / Total
    840 Watt
  • Input Impedance
    47 KOhm
  • Input Sensitivity
    200 mV
AMPLIFIER OUTPUT DETAILS
  • Output Power / Channel
    120 Watt
  • Output Impedance / Channel
    8 Ohm
  • Frequency Response
    20 - 20000 Hz
  • Total Harmonic Distortion (THD)
    0.04 %
  • Channel Type
    surround
  • Channel Qty
    7
RADIO
  • Tuner Type
    digital
  • Tuner Bands
    AM/FM
  • Tuning Display
    fluorescent display
  • Preset Station Qty
    40
  • Auto Preset Memory
    Yes
  • Antenna Form Factor
    loop AM / wire FM
  • Supported RDS Functions
    CT, EON, PS, PTY, RT
INPUTS & OUTPUTS
  • Headphone Jack
    Yes
  • Coaxial Digital Input
    Yes
  • Optical Digital Input
    Yes
  • Optical Digital Output
    Yes
REMOTE CONTROL
  • Type
    universal remote control
  • Remote Control Technology
    infrared
ACCESSORIES
  • Features
    LCD display, backlit buttons, learning, macro function, multi-brand compatibility
AUDIO SPECIFICATIONS
  • Type
    Amplifier
    10 - 100000 Hz
    100 dB
POWER
  • Form Factor
    internal
  • Power Outlets
    2 AC outlets
BATTERY / POWER
  • Type
    power supply
SIGNAL PROCESSING FEATURES
  • Video Conversion/Scaling
    S-Video to component video conversion, composite video to S-Video conversion, composite video to component video conversion
CONNECTIONS
  • Qty
    1, 2, 3, 4, 5, 9
  • Type
    7.1 channel audio line-in, HDMI input, HDMI output, S-Video input, S-Video output, SPDIF input, SPDIF output, audio line-in, audio line-out, audio line-out (multi zone), component video input, component video output, composite video input, composite video/audio input, composite video/audio output, headphones, monitor output, speakers output, turntable audio input
  • Connector Type
    4 pin mini-DIN, RCA, RCA x 2, RCA x 3, RCA x 8, TOSLINK, banana/spade x 2, one-touch x 2, phone stereo 6.3 mm
  • Connector Location
    front, rear
DIMENSIONS & WEIGHT
  • Depth
    17.2 in
  • Width
    17.1 in
  • Height
    6.7 in
  • Weight
    38.36 lbs
    Composite video to S-Video conversion, composite video to component video conversion, S-Video to component video conversion
Τον είχα παρει κοντα στα 1000 ευρω ..
και μονο για καθαρό δικαναλο να τον χρησιμοποιήσει κανεις αξίζει /
Στο 1/3 της τιμής στα 320 ευρω .
είναι 17 κιλα / δεν είναι για αποστολή
Μενω αθηνα \
pm me
ισχυει στα 290 ευρω , είναι κρίμα να καθεται - Ανταλλαγή και με καποιο καλό ζευγαρι ακουστικών αντιστοιχης αρχικής αξίας , ομοίως και με monitor ενεργά ή dac ,
gagakostas
