Yamaha Aventage RX-A2050
Πωλείται ο ενισχυτής του τίτλου σε άριστη κατάσταση. Αγορασμένος τον 06/2016 από Apothema.gr, έχει εγγύηση μέχρι 06/2018 από την Ελληνική Αντιπροσωπεία (ΝΑΚΑΣ) και ένα επιπλέον χρόνο από Yamaha Europe.
Τον έχω συνδεδεμένο με πολυκάναλο τελικό, οπότε ο ίδιος οδηγεί μόνο τα atmos ηχεία.
Τιμή 1.000 Ευρώ. Περιοχή Αθήνα. Επικοινωνία με π.μ.
Up και κάποια specs
9.2-channel AVENTAGE AV Receiver features Dolby Atmos® and audiophile-grade performance with the two latest ESS DACs and High-Resolution audio playback. It also supports 4K Ultra HD, WiFi, Bluetooth® and multizone features up to 4 zones.
  • Dolby Atmos® Support
  • DTS:X™ Support
  • AVENTAGE AV Receivers: Designed to Deliver the Highest Levels of Audio Performance
  • Aluminium Front Panel Offers Visual and Aural Benefits
  • Anti Resonance Technology (A.R.T.) Wedge helps to ensure that vibrations do not affect sound quality
  • H-shape cross member frame and rigid bottom frame
  • Professional quality digital audio by ESS DAC
  • 9-channel powerful surround sound
  • --- 140 W per channel (8 ohms, 20Hz-20kHz, 0.06 % THD, 2 ch driven)
  • --- 220 W per channel (4 ohms, 1 kHz, 0.9 % THD, 1 ch driven [European Model])
  • --- 220 W per channel (8 ohms, 1kHz, 10% THD, 1ch driven)
  • MusicCast for audio enjoyment in every room
  • Wi-Fi Built-in and Wireless Direct Compatible for Easy Network
  • Bluetooth for wireless music streaming and Compressed Music Enhancer for Bluetooth
  • AirPlay, Napster®*, Spotify®*, Pandora®*, JUKE* music streaming service and AV Controller app
  • *Music service availability varies by region.
  • DSD 2.8MHz/5.6MHz, FLAC/WAV/AIFF 192kHz/24bit, Apple Lossless 96kHz / 24-bit playback
  • Gapless playback compatibility allows play without interruption
  • High-resolution Music Enhancer further heightens musicality from the original content
  • 4K60p 4:4:4 Pass through, HDMI (8 in/2 out) with HDCP2.2 (7 in/2 out), 3D and Audio Return Channel
  • YPAO R.S.C. (Reflected Sound Control) sound optimisation with multi-point measurement
  • YPAO Volume to ensure natural sounds even at low volume
  • Virtual Surround Back Speaker for playing 7.1-channel content with a 5.1-channel system
  • Yamaha video processing optimises video content
  • Advanced HDMI Zone Switching allows unprecedented AV switching to multiple zones
  • Versatile Zone control such as Zone 2 / 3 / 4 on / off, Zone GUI and Party mode
  • ECO mode operation for about 20% less power consumption
kostas2025
