Yamaha Aventage
m1ts0s
News poster
Yamaha launches five Aventage AV receivers, prices start at £550
"This is the first time we've seen an Aventage model on sale at around £500 - and the addition of UK tuning shows just how much focus Yamaha has placed on this hotly contested pricepoint.
Besides the 'A550, there are four other Aventage receivers due to hit stores in late summer/early autumn: the RX-A850 (£900), RX-A1050 (£1000), RX-A2050 (£1500), and RX-A3050 (£2000).
All the new models support HDCP 2.2 for 4K compatibility, Bluetooth, wi-fi and high-res music playback, including DSD (5.6MHz), 24-bit/192kHz and FLAC, WAV, AIFF, ALAC, MP3 and WMA files. Dolby Atmos will feature on the RX-A850 and above, while DTS:X comes in at the RX-A1050 and above.
All the models use new, specially developed internal components, including a new jitter clock, designed to improve network capabilities, Bluetooth and USB playback of music files. The Aventage range also features a new volume control unit, which Yamaha claims provides smoother control over volume levels and dynamic range.
Some of the key differences between the models (besides power output) centre around the type and number of DACs used. The 'A1050, for example, uses a single ESS Sabre DAC, while the 'A3050 uses two different Sabre chipsets.
For this year's Aventage range, Yamaha has also made a few adjustments to its YPAO automatic speaker-calibration system, revamped the user interface and upgraded its AV Controller app."
spylab
Shalom
Μια χαρα , νομιζω εχει ερθει και η σειρα μου για καινουργιο μετα 10 χρονια με τον denon.
Για την τρομερη μου εγκρατεια νομιζω μου αξιζει ενας 3040 :)
Οχι ρε! Τον 3050 θα πάρεις! Θα αφησεις DTS:X απέξω και HDCP 2.2 και HDMI 2.0? Θα είναι DOA πριν τον αγοράσεις...
Μα αφού βγάζουμε τώρα 420€ αντί για 60€ βρε Σπύρο! :whistling:
εγω πιστευω οτι τα cc, πολυ πιθανο να οδηγησουν σε αυξηση τις αγορες καταναλωτικων αγορων , ειναι καπως το σπιτικο παστο.
stampol
Οι θυσίες...
εγω λεω....σε εξοδα να μπαινουμε ΠΑΛΙ γμ την τυχη μας τη ρημαδα!!!!!!!! :mad::mad:
Σπυροοοοοοο...... 1922€ ο RX-A3050 απο Ελλάδα. Πλέον δεν έχεις δικαιολογίες. Πρεπει να τον πάρεις!
Παιδιά έκανε κανένας αγορά?
Περιμένω τον 1050 και επιστρέφω με εντυπώσεις.
Η αλήθεια είναι οτι μπήκα στην διαδικασία μόνο και μόνο για τα sabre.
Ελπίζω να μην με απογοητεύσει στη μουσική σε σχέση με τον Aragon stage one που θα πάρει τη θέση του μόνο και μόνο λόγο βλάβης.
Α καθαρά σαν προ θα δουλέψει και ίσως στο μέλλον συνδέσω πάνω του δυο κανάλια ύψους.
Αυτά είναι μόνο για τοποθέτηση στο ταβάνι ή μπορώ να τα τοποθετήσω και πάνω στα front?
Άκυρο αυτό το είδα.
Το ιδανικό για μένα είναι να τοποθετήσω δυο ηχεία εκεί που δείχνει η εικόνα.
Ποιος τρόπος τοποθέτησης αποδίδει τα μέγιστα?
l.koustimpis@visualacoust
