YAMAHA CA-V1
YAMAHA CA-V1 Stereo Integrated Amplifier (1977)
Power output: 25 watts per channel into 8Ω (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.05%
Damping factor: 50
Input sensitivity: 2.5mV (MM), 150mV (line)
Signal to noise ratio: 77dB (MM), 100dB (line)
Output: 150mV (line)
Speaker load impedance: 4Ω (minimum)
Semiconductors: 40 x transistors, 26 x diodes, 1 x zener diode
Dimensions: 435 x 137 x 340mm
Weight: 8kg
Σε άριστη κατάσταση με εξαιρετικό ήχο και δοκιμή
Τιμή, 150
nickger
